D-100: The Official "Does This Wheel and/or Tire Fit My Car" Thread
#403
94 DC4 RS LSV/Turbo
i think it is great that you provide this information to other members. It really clears up all the b.s. Out there about what really fits. Thanks!!!
questions on wheels
wheel make/model: Konig crosshair
wheel size (**x**): 19 x 8
wheel offset (+**): +30 f & +40 r
if lowered (amount):
question on brembo/big brake clearance
transmission (manual or auto): Manual
year/trim (04-07, base or type s): 2005
if lowered (amount): Stock (keeping stock)
questions on tires
would like to run a 40 series in a 235 or 245???
Do people run 19 x 9.5 in the rear without rubbing?
Thanks again!
questions on wheels
questions on tires
Thanks again!
19x8 +30 wrapped on 225/40-19 FRONT
rear is a different scenario as there is no pesky brakes there
19x9.5 +40 wrapped on 245/35-19 or 255/35-19 works great
#404
94 DC4 RS LSV/Turbo
17" wheels with 235/45-17 is factory
18" wheels with 235/40-18 is accessory option
sooo
19" wheels with 235/35-19 is extremely close to factory spec thus, the diameter will be identical... YET you will get the "appearance" of sitting up higher because you have less tire sidewall
#405
Thank you for the info stillhere153... AKA TL Wheel&tire Genius! Would it be better to get the same set all the way around and rotate them to prolong tire life? If so, what would you suggest in wheel width and tire specs? Thanks again for your help.
#406
6th Gear
#408
Great!!!
Thank you for the info stillhere153... AKA TL Wheel&tire Genius!!! Would it be better to get the same set all the way around and rotate them to prolong tire life? If so, what would you suggest in wheel width and tire specs for my 05 w/ BBK? Thanks again for your help.
...ONE LAST OPTION QUESTION
wheel make/model: PRIVAT RENNSTADT
Thanks again for your help!!!
#409
ASA AR9's
Can't find these anywhere in the forum except on a white auto? Specs indicate they might fit on a 6sdp. VQMotoring says they do... Tire Rack says they don't! Can't find a PH# for ASA.
wheel make/model: ASA AR9's
wheel size (**x**): 19 x 8.5
wheel offset (+**): +40
#413
94 DC4 RS LSV/Turbo
#414
94 DC4 RS LSV/Turbo
i think it needs a 5mm spacer can't confirm
if they do clear there will be a credit card thick amount of space
#416
Learn me!!! I have never used spacers in the last 8 cars I have owned. Is it better to find a wheel that fits or does it hurt to use a spacer on a wheel you really want? I like the concept of the inserts on the AR9's and I do not want to spend a lot of $. How much do spacers cost and where can you get them? Wheel venders NEVER offer spacers... they just say they won't fit.
#417
94 DC4 RS LSV/Turbo
you can get 2 sets of ichiban spacers on ebay (5mm) for like 50bux a pair
http://cgi.ebay.com/ebaymotors/Ichib...Q5fAccessories
http://www.ichiba-usa.com/
#418
#419
I was looking at those before and even tho they say they are hubcentric and fit to the hub there doesn't seem to be a flange on them to accept a hubcenteric ring that goes into the wheel.
Thus to me would be like running an aftermarket wheel with no hubcentric ring.
If you look at thier thicker spacers that have the bolts you can see the tapered flange that would mate with the taper in an after market wheel .. I could be wrong.
#420
1st TL-S on air in
Will either of these wheels have Brembo Brake Clearance
Transmission- 6mt
Year/Trim - 08 Type S
Wheel Make/Model: Axis/Penta
Wheel Size - F 8.5 & R 9.5
Wheel Offset F- +35 & R - +40
Lowered all the way on Tein Basics.
Transmission- 6mt
Wheel Make/Model: MMR GT1
Wheel Offset F- +35mm & R - +45mm
Also recommended tires sizes for each setup. Thanks
Transmission- 6mt
Transmission- 6mt
#422
94 DC4 RS LSV/Turbo
Honestly I'd get a set made up by wheeladapter.con instead, except the price will be double that of ichiba
I will post pics for you of a spacer wheeladapter made for me
#423
94 DC4 RS LSV/Turbo
Transmission- 6mt
Transmission- 6mt
Transmission- 6mt
Transmission- 6mt
And the mmr I believe clear, couple members are running thosé
#426
please need help before i buy them or should i just get 18x8's all the wha around
Question on Brembo/Big Brake Clearance
Transmission (Manual or Auto):6 speed
Year/Trim (04-07, Base or Type S):05 tl with aspec kit
Wheel Make/Model:konig runaway hyper gray
Wheel Size (**X**):18x8-18x9
Wheel Offset (+**):35mm-30mm
If lowered (amount):eibach pro kit 1.0''
Questions on Tires
Tire Make/Model:falken 912 or 512's
Width/Sidewall-Diameter (***/**-**):235/40-245/40
If lowered (amount):1.0''
Questions on Tires
#429
94 DC4 RS LSV/Turbo
Questions on Tires
Questions on Tires
the konig runaway in 18x8 +30 will fit, +35 will require like a 3mm spacer
the rear 18x9 +35 fits no biggie
tire sizes are correct
#431
I have a question about what tire size I can run. I am looking at some TSW Snetterton. I am going to be going with 20x8.5 in the front and 20x10 in the back. The front have a 35 offset and the rear have a 38 offset. I wanted to run 245/35/20's in the front and 255/35/20's in the rear. I am also looking to drop it on coilovers but not for at least a year. And I would only drop it down like 1.5-1.75 inches. Will these work, or will i need spacer's and 30 series instead of 35 series? Any help would be great. Oh and they are going on an 05tl with no BBK
#432
94 DC4 RS LSV/Turbo
the tire size is off... here are your options
Front
225/35-20
235/30-20
245/30-20
Rear
245/30-20
255/30-20 (will require fender rolling)
Front
225/35-20
235/30-20
245/30-20
Rear
245/30-20
#433
Would my tired fit on these type of wheels? My other question is, which offset would be better to get for my car: +35, +40, or +45?
Wheel Make/Model:
Wheel Size (**x**): 18" x7.5"
Wheel Offset (+**): +40 or+45
Transmission (Manual or Auto): Manual
Year/Trim (04-07, Base or Type S): 04 Base
Wheel Make/Model:
Wheel Size (**X**):
Wheel Offset (+**):
Tire Make/Model: Michelin
Width/Sidewall-Diamete:235/40z/r18
Wheel Make/Model:
Wheel Make/Model:
Wheel Size (**X**):
Wheel Offset (+**):
#434
Transmission (Manual or Auto):man
Year/Trim (04-07, Base or Type S):08 type s
Wheel Make/Model:TSW Croft
Wheel Size (**X**):20x8.5
Wheel Offset (+**):40
If lowered (amount):1.5 can raise or lower to make fitment right and look good on tein ss
Questions on Tires
Tire Make/Model:!!!!what tire would be good for this wheel if it will work?!!!!
Need a spacer?
For 5mm H&R/Eibach or Ichiba work
For 5mm or greater visit wheeladapter.com (custom widths available)
Extended Wheel Studs are always the best way to go[/QUOTE]
Questions on Tires
Need a spacer?
#435
Wheel Make/Model:
Wheel Make/Model:
Wheel Size (**X**):
Wheel Offset (+**):
Wheel Make/Model:
Wheel Make/Model:
Wheel Size (**X**):
Wheel Offset (+**):
#436
94 DC4 RS LSV/Turbo
Wheel Make/Model:
Wheel Make/Model:
Wheel Size (**X**):
Wheel Offset (+**):
Wheel Make/Model:
Wheel Make/Model:
Wheel Size (**X**):
Wheel Offset (+**):
18x7.5 will not clear your factory brakes... you need at least an x8..
18x8 +35 on the 235/40-18 is a good fit
#437
94 DC4 RS LSV/Turbo
Questions on Tires
Need a spacer?
Questions on Tires
Need a spacer?
235/30-20 so you wont rub.... but it will leave you with almost no rim protection
#438
How can one determine a wheel will or won't fit if the brand of wheel isn't mentioned .. I don't see where Magmar04 posted the wheel brand .. just the sizing. Isn't there a lot of 18 x 8 +35 out there that won't clear the brakes?
#440
94 DC4 RS LSV/Turbo
Just a question here or am I reading things all wrong?
excluding the axis widetrack which is geared to be for extended lips
that wheel is 18x8 with an option of 2 lips, 60mm and 90mm, the lips width is created by offering less inner clearance also known as backspacing
for more information on my method of prediciting and pretty much being on the money on wheel fitments, see this thread for all the details you need to know
https://www.rsracing.com/tech-wheel.html
