Correct Tire Pressure?
Hello all,
I have a 06 6mt question about the tire pressure...what should it be? I run about 37 in the fronts and 33 in the back. Would that be a problem? What do u guys/gals run/recommend?
thanks in advance!
thanks in advance!
Check your owner's manual. It has the manufacturer's recommended tire pressure in it.
Then you can adjust it by raising or lower it, depending on how you like the car to ride and handle.
On that note, 37F/33R isn't a bad setup. I usually run 35/33 during the summer and 37/35 in the winter.
tires pressure go up about 3-4 PSI on average on a normal day...on long distance driving or real hot day they can go up 5-6 PSI so whatevr you put in the tires make sure you compensate for this...i know this from reading the measurement from 06 loaner TL with TPMS....and i believe the max pressure for EL42 is 40 PSI...not sure
Originally Posted by atCLown
Hello all,
thanks in advance!
thanks in advance!
Originally Posted by Yakuza70
If I'm not mistaken, I think Acura recommends 35 front and 32 rear for 6MTs. That's what I keep on my '05 6MT with Michelins. I'm not sure why but I think they recommend 32 front and 32 rear for the automatics.
Hard to figure out why they specify 32 for front and rear for the auto's, but the wear patterns support their recommendation, as does the 35 front and 32 rear for the manual.
Originally Posted by SouthernBoy
You are exactly correct.. at least for the '04 manuals and the '05 automatics. I know.. I have one of each.
So if the manual says 35/33 for stock tires, if we get aftermarket tires whose max pressure cold is 50psi, should we be running the psi of stocks?
If the tires are not direct replacements (as in a different size), start with the factory recommendation and pay close attention to wear and handling.
mugen_kid
Nov 13, 2015 10:38 PM
Oakes
Wash & Wax
Oct 12, 2015 11:17 AM
NBP_BALLER
Sep 23, 2015 08:18 PM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
HeloDown
Sep 8, 2015 06:51 PM
