Camber Kit
I would contact either heeltoe or excelerate in regards to this matter... Discount tire wouldnt know the difference between an apple and an orange. They would say a 225 tire will not fit onto an 8.5 wide wheel.
Since I couldnt edit, here is proof.
SPC camber kit via Exelerate http://store.excelerateperformance.c...5/i-68794.aspx
Or through camber kits heeltoe
http://www.heeltoeauto.com/home.php?cat=2158
94 DC4 RS LSV/Turbo
at $50+ more... enjoy i just dont see the reasoning in paying over $50 per side for something you can essentially have custom made using stock parts
Former Sponsor
No your toe is off b/c you changed the height of the suspension, thus the reason for an alignment. Your camber is off b/c you changed the height, thus the reason for the camber kit to adjust camber on the alignment rack. The Wicked kit is just like the SPC kit; it doesn't adjust toe. The Ingalls kit includes 2 arms per side to adjust camber and toe since the stock arm has very little adjustment for toe.
94 DC4 RS LSV/Turbo
for the record my toe being off has nothing to do with my drop...(Car was aligned 2 times post drop) it has all to do with nyc roads (bumps)... AND IT IS CORRECT NOW AND CORRECTABLE WITH A 1.5" DROP
reffer to my reply in the wicked rear camber kit regarding the "little adjustment" false theory
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
