Biggg problem!!!!
Old May 12, 2009 | 08:16 PM
LwPTL1223's Avatar
ACTASY
Exclamation Biggg problem!!!!
take a look at this and let me kno what you think!!!!
As you can see its only seperating on half of the tire not all the way around WTF!!!
Old May 12, 2009 | 08:21 PM
marmaladedad's Avatar
Did you run over something?
Old May 12, 2009 | 08:22 PM
LwPTL1223's Avatar
ACTASY
no? idk whats the deal man i really makes me curious...and this only happened on the one side!
Old May 12, 2009 | 08:28 PM
quasi's Avatar
Dude, this exact problem happened to me too, on 2 tires, both on the rear, apperently, it was due to lack of tread and cornering hard, causing the tread to seperate and having the belts exposed, hope this helps
Old May 12, 2009 | 08:30 PM
LwPTL1223's Avatar
ACTASY
so you dont think its front rubbing? because my car hasnt been rubbin....i was very shocked when this happened....my wheels are balanced and im gettin a bad vibration around 65 70 does any one have a solution?
Old May 12, 2009 | 10:09 PM
Bearcat94's Avatar
AZ Community Team
Looks cut. Usually from rubbing.
Otherwise -
Old May 12, 2009 | 10:19 PM
Jesstzn's Avatar
Camber & toe in off and not enough air pressure. Causes heat and the tire separates.
Old May 12, 2009 | 10:22 PM
MR1's Avatar
MR1
05/5AT/Navi/ABP/Quartz
I think it's a defect resulting in the seperation. This is a weak point where the belts end. Depending on mileage may be warranty.
Old May 12, 2009 | 11:52 PM
dubs_are4me's Avatar
I think the problem is due to excessive camber or toe it will murder tires.
Old May 13, 2009 | 12:20 AM
Fulani has a TL's Avatar
Agreed with above, looks like camber. How is the treadwear on the otherside of the tire?
ps. you got some balls to put the face of the wheel right on concrete!! ahhh
Old May 13, 2009 | 09:23 AM
djbonsu's Avatar
"Like None Other"
Originally Posted by dubs_are4me
i think the problem is due to excessive camber or toe it will murder tires.
^^^+1
Old May 13, 2009 | 09:51 AM
Tripnbeats's Avatar
well from the spec on the tire it doesnt seem to be the wrong setup....that seems really odd.... check the ball joints top n bottom by moving the tires in up n down side to side in n out movements. all of those movements are supposed to solid if theres play theres a problem. check the control arm where it connects to the sub frame for cracking or seperation in the rubber.
Old May 13, 2009 | 09:54 AM
Tripnbeats's Avatar
and yes excessive camber or toe is correct but from what is the question.
Old May 13, 2009 | 05:40 PM
LwPTL1223's Avatar
ACTASY
i have a camber kit on the car....the camber is set right...and the wear on the other side of the tire is fine....and its only this one tire?
Old May 13, 2009 | 10:46 PM
is it the left front tire?
Old May 13, 2009 | 11:22 PM
dtan1691's Avatar
mayb its becuase you hit a pothole? And it slashed apart of your tire and now your wheel is bent thats why it vibates at higher speeds... Same thing with my wheels, they are slightly bent, so it vibrates after 80mph
Old May 13, 2009 | 11:37 PM
Cerezo's Avatar
i see a scratched up rim
Old May 14, 2009 | 12:30 AM
EvoToTL's Avatar
Former Street Racer
looks like u had too much negative camber. Samething happens to stock evo's with stock tires the inner wears out fast due to negative camber.
Old May 14, 2009 | 08:11 AM
alexSU's Avatar
Under construction
Honestly, that's why I never bought kumho's again. I had them once and that shit happened! I know alot of people like them cuz they are cheap, but this is what happens when you try to cut corners.
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
MikeJM310
Sep 24, 2015 07:24 PM
