Best replacement/upgrade rubber for stock 04 rims?
Old 04-01-2005, 07:42 PM
3rd Gear
grobertw's Avatar
I am replacing my the tires on my stock 04TL (auto). I was hoping to go with a little bit wider & taller tire but dont want to take a chance on getting too big so they rub (especially since I will be ordering off net).
Also looking for as quiet as possible from an all season tire. if anyone is willing to make a suggestion on size and brand I would very much appreciate it.
Thnxs
Gary
Old 04-01-2005, 08:19 PM
ibeplato's Avatar
Search previous threads and you'll find the favorites down to the Pirelli PZero Nero, Toyo Proxes 4, Falken ZIEX 512, and Michelin Pilot Sport A/S.
I just put the Pilots on mine, exact replacment for the 17" Turanza ELs. They are great tires, a bit priceir than the others, but I've always had luck with Michelins. I paid $894 at Costco including installation, lifetime rotation/balance, road hazzard insurance and all other fees (and they fill the tires with Nitrogen).
Old 04-01-2005, 08:30 PM
MichiganRich's Avatar
I'm going to go with Avon Tech m550's at Tirerack. I had pretty much narrowed it down to the Michelin PS2s, Pirelli Nero Zeros, and the Avons. I called Gary at the Rack and he said the Mich's would be too sporty and hard for what I wanted, and that the Avon would be the quietest. He said I couldn't go wrong with either the Nero Zeros or the Avons, but that he would lean toward the Avons for comfort. I specified that I wanted a quiet comfy tire with excellent wet grip and decent treadlife.
Old 04-01-2005, 09:07 PM
3rd Gear
grobertw's Avatar
sizes?
Thanks much on the brand info, does anyone have any size upgrade suggestions? I could not find info on that in the other threads if I am looking to put something a little bigger (wider/taller) on stock rims. If OEM tire is 235/45 17, I wonder if 245/45 17 would work? I belive the 245 means 10MM wider than the 235's and the 45 would be slightly taller as it is a percentage of the tire width. Anyone care to comment? Thanks much for your help.
Gary
Old 04-06-2005, 02:30 PM
Vtecne's Avatar
I am using 245 45 17 Z rated tire BF Good ridge Sports and they feel better than the stocks. Bridgestone tires run 1/2 size bigger than most tires. If you get a 235 from another manufacturer it will look to small, the 245's look and feel better than stocks. My .02 cents worth. Also BFgoodridge is made by Michelin.
Vtecne
Old 04-08-2005, 07:06 PM
3rd Gear
grobertw's Avatar
Thanks for the feedback all!
I had to balance $ and performance so I ended up getting Falken Ziex ZE-512 235/45ZR-17 @ $103.00each . They go on Monday, I will post my results after that.
Old 05-13-2005, 08:58 AM
ITL
I do my own work.
ITL's Avatar
To you guys with 245s, are any of you lowered?
Old 05-19-2005, 09:58 AM
3rd Gear
mrobrien's Avatar
Thanks for the Tip
Following your advice, I got the Avons from tirerack.com and got them installed yesterday. So far, they appear to handle better, are quieter, and are very affordable. I got the 245 (instead of the 235) so I don't scratch my rims anymore.
Thanks!
Michael
Old 05-19-2005, 11:18 AM
Team Anthracite Member
TBone2004's Avatar
Flatspotting?
Any pics of them on rim/car
Thanks!
Michael
Old 05-19-2005, 01:30 PM
ITL
I do my own work.
ITL's Avatar
Bought 235s...very happy with my Toyo Proxes 4s and the rim lip protector. Cool tread pattern and smooth, quiet ride- yet firm.
Old 05-19-2005, 01:47 PM
3PUTT's Avatar
lowered here...no rubbing.
Old 05-20-2005, 08:17 AM
ITL
I do my own work.
ITL's Avatar
wish you had responded a week ago...I would've defintiely gone with the 245s. oh well, next time...
Old 05-20-2005, 10:50 AM
neuronbob's Avatar
Received 4,613 Likes on 2,193 Posts
Has anyone had the Avons for an entire winter? What sort of winter performance do they offer?
I just got a bubble on one of my Falkens and am looking to replace. I'll likely go with a pair of Falkens (or maybe replace all four...) to replace, but it's nice to know about other options. Still not ready to blow a grand on the Pilot Sport A/S, only to see one bubble out on typical Cleveland roads....
Old 05-21-2005, 08:00 PM
Registered Member
SouthernBoy's Avatar
I would strongly advise against going with a "taller" tire. Such tires will have a detrimental affect on acceleraton.. as in reducing it. Going to a taller tire is the same as going with a taller (higher) gear (final drive ratio). Acceleration will indeed, suffer.
james357
02-13-2016 02:37 PM
V-tecAc
09-21-2015 09:25 AM
jaimbot
09-17-2015 09:25 AM
ddietz
09-09-2015 07:00 PM
bailey24
08-31-2015 05:38 PM
Quick Reply: Best replacement/upgrade rubber for stock 04 rims?
