Aspec wheels vs Base wheels
Old Feb 5, 2017 | 06:32 AM
Craigss81689's Avatar
Since the Aspec rims are 18s and possibly weigh a little more than the 17" base rims, wouldn't the base TL be a little bit faster than an Aspec package TL? Just wondering why online it's posted that the Aspec pulls a 14.25 in a 1/4 and the base a little bit slower.
Old Feb 5, 2017 | 08:49 PM
srg818's Avatar
Lighter suspension components?
Old Feb 5, 2017 | 08:50 PM
Driver mod
Old Feb 5, 2017 | 10:04 PM
truonghthe's Avatar
Suspension in the Aspec is stiffer and tire sidewall is thinner therefore tire flex and put power down more efficiently.
Old Feb 6, 2017 | 12:55 AM
WDPanda's Avatar
The spokes are thinner so that saves some weight.
Old Feb 6, 2017 | 06:24 AM
LOL are you seriously trying to find out over a few milliseconds?
Old Feb 6, 2017 | 01:27 PM
Just was wondering because I haven't been looking at 18" rims to avoid getting heavier wheels
Old Feb 6, 2017 | 01:31 PM
What if I told you that there were bigger wheels that could be lighter
Old Feb 6, 2017 | 01:34 PM
first, where did you get your source that the aspec did the quarter faster?
IIRC, the only thing the aspec did better was around a track.
this was due to the aspec kit having less drag coefficient, or more? which ever number is the better drag coefficient
Old Feb 6, 2017 | 01:35 PM
if that's all you wanted, just weigh the two wheels and subtract the difference.. .
OEM wheels are gonna be heavy, clockin at 32-38lbs...add a tire...you're looking at ~50lbs per corner.
Old Feb 6, 2017 | 01:36 PM
TacoBello's Avatar
Yes, and the extra inch of wheel diameter is to be ignored?
Old Feb 6, 2017 | 02:17 PM
04WDPSeDaN's Avatar
iWhine S/C 6MT TL
The 3rd gen TL is starting to show it's age. 1/4 posted times are great, but also done when these things are new. Not many 3rd gen TL's can nail 14.2 in stock form. The A-spec package has been know to make the TL a bit slower. The A-spec wheels are slightly heavier than the base model wheels. The 3rd gen TL is slow to what's out there now, so I wouldn't worry so much about 1/4 times and if A-spec wheels will slow the TL down. Unless you drop some serious $$$ to make the TL quicker..
Old Feb 6, 2017 | 02:23 PM
I have one of the industry's lightest weight wheels but at 18 inches and it didnt cut as much weight as I thought it would.
I'm rockin TE37's and they only shaved like 2 lbs...although i'm running 18x9.5, so there is a lot of aluminium there
with tires, it;s still something like 50lbs per corner
Old Feb 6, 2017 | 03:32 PM
truonghthe's Avatar
You better stop eating Pho, its time to switch to pure salad diet...
Old Feb 6, 2017 | 03:47 PM
TacoBello's Avatar
and that's where the looks vs function balance comes in. If someone wants to be the fastest they can, they should stick to lightweight 17s, without a super wide barrel. But then they're paying a lot to look like ass, which not many people want. So it becomes the balancing game. I think the fact you were able to move up an inch in diameter and 1.5" in width, while still saving wheel weight, you're pretty golden.
however, as you already alluded to- with bigger wheels, come bigger tires. And that can make a huge difference per corner, especially if your wheels are wider than before. For ultimate weight savings, a guy should stick to a forged 17x8 wheel... But who wants to do that?
Old Feb 6, 2017 | 04:57 PM
Oh Sickest TL's Avatar
Jeff
my 18x9 advans shed a fuck ton of weight on my car.
I felt the difference instantly. But not everyone has coin to drop on advans let alone for a TL
Just stick to the A-spec wheels, this is not a race car nor will it ever come close to being one..
Old Feb 6, 2017 | 05:13 PM
TacoBello's Avatar
I find that hard to believe.
Old Feb 6, 2017 | 05:15 PM
Jeff
what hard to believe? the car is much lighter on its feet now. those advans are paper light. Or are you meaning something else lol
Old Feb 6, 2017 | 05:21 PM
TacoBello's Avatar
Are they forged? inthought the majority of Advans are cast.
as spaceman pointed out, he's got one of the lightest wheels on the market and he only shaved 2lbs off per corner. granted, his barrel is 0.5" wider than yours, but the barrel isn't nearly as heavy as the rest of the wheel.
Also, have you rode on your OEM wheels since? My "18 enkeis are lighter than the 17" OEM wheels... But the wider tire needed on them
negates much, if not all the weight savings. And because of the additional width of my enkeis, when I put the stock wheels on for the winter, the car feels waaaay lighter on its feet. There's no way a wider wheel feels as responsive as a skinnier one.
either way...
Old Feb 6, 2017 | 05:26 PM
Jeff
hmmmmm
​​​​​​​well I went up in wheel size but down in tire size lol
I had all the weight savings documented somewhere in my thread and it was figured out to be around 4-5lbs per corner compared to the waffles
even just lifting the 2 one after the other it was like holy shit this feels like paper
regardless a minimum of 10lbs rotational mass lost is great no matter what
Old Feb 6, 2017 | 06:56 PM
WDPanda's Avatar
it's not to be ignored, which idiot thought that? The savings offset the extra inch of metal of course.
Old Feb 7, 2017 | 09:46 AM
Factory wheels 32 lbs without tires? I thought I read that they were 24lbs? I found some 17" wheels online that are only 20.8 lbs so that should be my best bet then
Old Feb 7, 2017 | 09:52 AM
i mean, even if i did get the weights wrong... it still is about 50lbs per corner with tires...
I agree with TACO, 17's with concerns about weight will look like ass.
it's a balancing act of looking good and lower weight
but like El Jeffe said....shaving 2lbs per corner is still a big difference
thus why asking questions about personal modding is hard...because everything is PERSONAL.
I have my own goals...Taco has his own goals, El Jeffe has his own goals...
YOU have your own goals....
so the best bet is to weigh them yourself. and choose accordingly to your goals.
Old Feb 7, 2017 | 11:11 AM
TacoBello's Avatar
I agree... shedding just a few pounds at the drive wheels makes a huge difference overall. I was being thrown off by El Jeffe saying his new wheels were "paper light"... it's still like 45 pounds per corner
Old Feb 7, 2017 | 11:15 AM
right, we can argue about semantics and definitions and each other's goals...
BUTT at the end of the day, it's personal and what you do WILL be different than what any of us do. that's the joy of being an individual! (with a brain)
make smart choices!
Old Feb 7, 2017 | 11:39 AM
TacoBello's Avatar
so then why do some of us ask others what color to paint their own calipers?
Old Feb 7, 2017 | 11:42 AM
lmao that irks me so bad.
like how does one get dressed in the morning without asking the internet...
Red is obviously the fastest color..
Old Feb 7, 2017 | 11:43 AM
Oh shit.. you found that thread I made this morning?
Socks first or pants first?
Old Feb 7, 2017 | 11:53 AM
Believe me, OP...at one point and time..I wanted to be the fastest 6MT TL in Houston.
I took out a bunch of dead weight and modded the car with go fast goodies.
the thing is, there will always be some one faster than you.
after my dreams were smashed i decided that putting ALL my effort into the car was not something i wanted to do any more.
She's a looker and she does what I ask, when I ask. that's all I need from the TL!!
Old Feb 8, 2017 | 09:40 AM
truonghthe's Avatar
^^^ He still the fastest TL in Houston, well fastest at getting a ticket racing against Mexican civic that is....
Old Feb 8, 2017 | 09:42 AM
hahahahhahahahhahahahahha
cop gave me verbal warning...and i fuckin smashed that civic
Old Mar 7, 2017 | 04:53 PM
Update
i ended up purchasing 18x9.5 +30 Work emotion CR Kiwani Ultimates with 245/40/18 perrelli tires and noticed a little difference. Previously my car had base 17" oem wheels with 235/45/17 continental tires. My overall experience of my newer wheels is that my car drives a little different now. Picking up my Kiwamis did feel lighter than my base wheels and the car does drive differently. I wouldn't say it's faster it's more of a weird feeling. My kiwamis are 22 pounds and the base are apparently 25 pounds. I did notice now my wheels will skirt in first gear when vtec engages. Honestly I wish I took my car to the track before then after to see the difference.
