ASpec Drop
Old 06-09-2004 | 08:14 AM
1acura's Avatar
ASpec Drop
I tried a brief search, but I'm late for a meeting so I'll just ask. If I buy the ASpec suspension it drops the car .5 inches (good for me b/c I'm not into the whole lowered look). Now my question is this, in stock form the front wheel gap is slightly greater than the rear wheel gap. Does the ASpec suspension correct this and make it even? I'm guessing it wouldn't since I'm reading that it is a .5 drop both front and rear, but I would like to hear from an ASpec owner. Thanks all.
Old 06-09-2004 | 05:47 PM
1acura's Avatar
thanks.......
Old 06-09-2004 | 11:22 PM
Aegir's Avatar
Powered by Guinness
My car is 26 1/2" fender to floor - all four corners. Measured even with the center of the wheel, perpindicular to the floor. Hope that helps.
Old 06-10-2004 | 06:13 PM
1acura's Avatar
Thanks. That is what I wanted to hear.
Old 06-10-2004 | 08:56 PM
ComptechType-S's Avatar
Time to POWER UP!!
I have the comptech springs and my rear wheel gaps are a little smaller that the front ones. I have seen some cars that look perfectly level after the spring install. Its prolly my stereo stuff that makes mine a little lower
Old 06-12-2004 | 04:01 AM
JDOWNLOW's Avatar
7th Gear
howz the ride quality compared to stock with your comptech? is it harsh (be subjective/honest)? how was the install? how is your camber?
thanks jeff
Old 06-12-2004 | 11:18 AM
Time to POWER UP!!
The ride quality is great for me. I like a more sporty ride over a soft ride any day. I did the Comptech springs and 18's at the same time and the steering response seems faster and the handling is much improved. With the TL being so heavy the car wanted to "push" out when going into corners too fast but after the drop and wheels it handles much better.
The camber is OK for now.. As the car settles, if the camber gets over 3 tenths, i'll do a camber kit. Right now it is at 2.5, the specs say .20 from the factory.
Old 06-13-2004 | 02:40 PM
JDOWNLOW's Avatar
7th Gear
do you have any pictures of your car? thinking about lowering mine but really only want to get rid of the gap in the front. How low do the comps lower your car? If it's only 1" in the front and .5" in the back, you think just lowering the front would be fine?
thanks
jeff
Old 06-14-2004 | 11:25 AM
Michaelvg1's Avatar
I think mine are perfect....
Old 06-16-2004 | 02:15 AM
JDOWNLOW's Avatar
7th Gear
checked out the pictures of your car online. sweet. I have same color but no aero kit. Which spring did you install and how is the change in the ride?
Old 06-16-2004 | 07:47 AM
Michaelvg1's Avatar
Thank you.
Since it's leased, I went with Comptech for $400. Ride is a little tighter, but not that bad. Little sportier. I always thought the cars were way to high off the ground anyway.
Old 06-18-2004 | 05:46 AM
JDOWNLOW's Avatar
7th Gear
Thank you.
how much did it lower your ride front and back?
Old 06-21-2004 | 08:16 AM
Michaelvg1's Avatar
1 inch
emailnatec
29
09-28-2018 05:27 PM
RL780
10-19-2015 10:46 AM
Nickb257
ILX
30
10-11-2015 03:43 PM
us285126
10-02-2015 03:03 PM
4drviper
09-23-2015 08:42 PM
