anyone w/Axis Se7en Mods?? questions
1 Post
anyone here have a TL (especially 6spds)with axis se7en mods in 19?? I have them on my CL wanna put them on my TL-S, wanted to know 1) If you have a 6spd or Type S, did you use spacers to clear brembos. 2) if the tire pressure sensors are compatible on these rims.
If i have to use spacers is there anything i should be looking for or where should i get them. With the warm weather coming im dying to get them on the TL-S
also if you have these rims on, do you have pics to post of them on your TL
I don't think you can spacer the wheels to clear the fronts without going crazy or rubbing. What's your offset now? I would guess 40 mm. The thickest spacer you can fit without rubbing is about 10 mm. But because the spokes curve inward so much, they might even still hit the calipers. Sooo, the best way is to measure the caliper clearance of the wheels first, then go from there.
Thanks for the compliments. The wheels are Volk Racing GT-V, in 19x8.5 with 35 offset. The avatar shows the car with Koni Yellow and Eibach Prokit with lowered front spring perches.
I had 19" se7en mods on my auto TL(they're in storage, awaiting tires), also hand-me-downs from my CL-S. They BARELY clear the calipers. I imagine they would be a no-go with the Brembos.
I agree with 260 HP. I think the best way is to try it. That's what I did, and I lucked out.
As soon I figure out how, I 'll post pics.
06 TL 6spd. Navi/A-spec
I had 19" Axis Seven mods in black with a chrome lip and i tried to put them on my 6-speed but they didnt clear the calipers, so i sold them to a member on here, there is another member on here "typeacuratl" also with NBP w/ 19" axis seven mods here is his car
1 Post
Whats the best way to search for rims that will work on the type s? every wheel site i go 2 doesnt seperatate the ones w/o the brembos and the ones with them?
I too wanted the Axis Mod Sevens on my 07 type S but was told they wouldn't clear the calipers. I'm currently looking into Volk GT-7's but wanted to know if anyones found a way of fitting the Mod's on the Type S.
Also, does anyone know what the offsets are on the Type S w/the stock rims? When you're searching for rims on the net, is there another way of knowing if it'll fit your car?
BoricuaTL
04-08-2016 01:08 PM
mrkingstonvi
02-22-2016 01:53 PM
