Alignment Readings after installing Tein SS
Hey everyone, I've been a lurker on this quite for sometime now and never really decided to start posting until just recently. Well to make a long story short, we got the oem bodykit, tein ss, and axis matrix wheels installed a couple weeks ago. Just this past weekend, I got the alignment and these are the results. It's a little faint and i apologize.
I'm not sure if it will load up properly but just to sum it up
Front: Left
Camber: -0.93
Caster: 3.41
Toe: -0.01in
Front: Right
Camber: -1.30
Caster:3.43
Toe:0.00in
Rear: Left
Camber: -2.28
Toe: 0.04
Rear: Right
Camber: -2.17
Toe: 0.04
I've read the sticky in regards to camber kits but I'm assuming with this much camber in the rear, it's going to wear a little more than i'd like. Now here's my question:
With my camber being as "bad" as it is in the rear, which camber kit should I run? I know SPC and Ingalls both have one but is one better than the other? Which specific model should i get? Thanks everyone in advance!
![](http://img.photobucket.com/albums/v650/rockstar937/scan0001.jpg)
Front: Left
Camber: -0.93
Caster: 3.41
Toe: -0.01in
Front: Right
Camber: -1.30
Caster:3.43
Toe:0.00in
Rear: Left
Camber: -2.28
Toe: 0.04
Rear: Right
Camber: -2.17
Toe: 0.04
Place a call to Marcus at Mr HeelToe- an acurazine vendor- at 1-949-295-1668
He is near LA and has the parts and knowledge needed to hook you up
wow here's a good story for you guys....on the way to school today, there was a pothole i swerved to miss, the bad thing is that there was a huge cement rock right past it so when i swerved to miss the pothole, i hit the rock and bent our new wheel. Thankfullly the tire did not blow out....now the wheel is in the wheel shop getting repaired and reclearcoated...damn
yeah tell me about it italian_spak...it's too bad cause it's only a Monday too! As far as the drop, all i know is that I have a little less than a finger gap.
Big Moe, thanks for the suggestion. I actually went ahead and ordered the ingalls camber kit for the car.
Thanks for the responses everyone.
Keep in mind when lowering- the recently discovered rule used by LE in California
Headlights must be 22 inches from the ground Minimum
What a way to get busted for everything else!
hahaha i apologize you guys... i'll take the pictures when I find my cable...I'll take a pciture of the right side since the drivers side has one axis wheel and stock wheel! i'll take em right now actually...brb
i apologize for the poor pictures and the dirty car but it's inside the garage...i'm too embarrassed to park it outside with one stock wheel on the driverside front. When I take better pictures, i'll post it in the proper forum
Former Sponsor
Ingalls offers a better setup than SPC, at least for the rear. Ingalls sells 2 arms for each side, one for camber and one for toe.
https://acurazine.com/forums/sponsored-sales-group-buys-10/ingalls-camber-kit-sale-acura-cl-rl-tl-tsx-352963/
nanos
11-12-2015 08:41 PM
asahrts
09-04-2015 05:55 PM
