Ahh My Sway Bar!
Ahh My Sway Bar!
Guys I need help here. Okay, so I install my Comptech sway bar and previously tested my handling before the install. The install went flawless however i took my car to test out the handling of it with the bar in, but it sucks now! It says to torque it to 25 ft/lbs but I think I did it a little more, do to peer preasure in my auto class. Do you guys know if this could be the problem as to why my handeling got worse?
Unless you're off by a lot, the torque spec wouldn't affect much at all.
I must ask the same questions as NFLblitze1; how exactly is your handling worse?
And don't listen to high school auto class people. They don't know shit.
i never pay attention to torque specs unless its on brakes or engine heads...
if you have a defective sway bar maybe, but that should not cause any problems otherwise
I installed it corectly, and now it is wierd. When I took my car to the parking lot and made sharp turns the back tires were squealing and it wouldnt take the turns as sharp. i can definitly feel the difference in how its so stiff in the back but it doesnt hadle any better.
Sounds like your handling exspectations are very high so you are blaming the bar for not meeting those expectations. A rear bar will improve the handling but it will not turn the car into a super-handling racecar. The job of the bigger rear bar on a front-wheel-drive car is to remove some cornering load from the heavily-tasked front tires and add it to the rear tires. This improves turn-in and allows the front wheels to accept more load before they finaly start to slide. The added rear loading can cause the rear tires to slide easier than before. Either way you are still limmited to the overall grip of the tires so you might want to look at a set of good tires to get the best handling.
Well Since I'm interested in getting one I'm a little scared my car post install will handle worse? In what ways does it handle worse?
Burgman: you sound pretty well informed. That explanation alone makes me think I should order one tomorrow lol.
I don't however want worse handling.I want a little more confidence going into the corners and less like bounce or roll. Im not sure if thats cause of the springs though. My 350z didnt have a rear sway or a front one,it did have a bar across the engine. It handled sooooo good...
Thanks for the info...
You wont get worse handling, the RSB on a front wheel drive car is one of the best upgrades you can make , it will flatten the car in cornering and make the car more stable and less floaty in the rear end.
Think about freeway on ramps (the tight turny ones) I guarantee you will be able to take them faster with more confidence.
Stavebomb, just for the record. What is your suspension configuration? Stock, lowering springs/stock struts, lowering springs/aftermarket struts, or aftermarket coilovers? Maybe this help diagnose your problem. IMO, I don't think it's the RSB.
As far as I know, Comptech has the only RSB for 3G TLs.
Well in that case, then I will be ordering mine very soon.
May sound dumb but is CompTech the only company that makes one for the TL or the best one?
The thread-starter may have a point.
Handling/cornering feels noticeably different & tires chirp more at FULL throttle on SHARP turns.
On a freeway on-ramp (tight sweeping right turn)....I floored it in 2nd (AT) doing about 55-65MPH (sign 'suggested!' 30MPH) and the car definitely took the corner sharper and the tires bit more than normal...BUT
At the end of the sweeping turn, the REAR actually OVERSTEERED---I was turning RIGHT and normally the FRONT would slide to the LEFT-thereby understeering----but this time----the car's REAR end fishtailed to the LEFT while I was turning RIGHT----thereby sliding the FRONT of the car to the RIGHT---and close to doing a 180-----something i did not think this FWD car would do. In my BMW, the Rear would slide left but it always centered out or even understeered at the end because of the Stability Control.
Fortunately, I grabbed control and pulled it back straight, I was surprised the Acura Stability Control didn't kick in earlier, I know its the new RSB, I wanted to really figure out what it could do, but now I figured out its limits. You can take corners a little faster but WATCH OUT for...... oversteer.....I don't think the Acura Stability Control knows what to do with it.
Happy Motoring.
P>S> I can't remember, now that we have OVERSTEER, is there is rule against letting off the gas pedal on a turn?
Happy Motoring.
Happy Motoring.
Happy Motoring.
Whether you get throttle-on oversteer or not, you shouldn't let off the throttle in a corner in a FWD because it will induce lift-throttle oversteer. By letting off the gas pedal, the front tires will no longer be pulling, and "lock up", causing the rear end to spin out. This is how I lost control of my car on the track going 80 mph on a rainy day. Don't try it at home.
Happy Motoring.
Happy Motoring.
If you had your 20" chromes on that will effect the handling as well
Oh and thanks Andenaline, for the info & tip, I think thats what happened to me, I should have stayed on the throttle instead of letting off after flooring it before.
ExcelerateRep
Sponsored Sales & Group Buys
09-22-2015 10:39 AM
