225/55s on stock rims don't rub (response to private email)
Old 10-06-2002 | 11:01 AM
sparky57's Avatar
I checked my profile because I was not getting notified and discovered I hadn't updated my email since AT&T changed it. I saw a private email asking if my tires rubbed. I fixed my email and intended to get back and respond, but the message went away.
So, Don (?) I have experienced no problems whatsoever with the 225/55 size. Haven't had to trim the infamous plastic tabs either. The first time I replaced tires, I went with Goodyear 215/55s and found that they were really too short. Speedo calibration was off and admittedly, they didn't look as good. After reading that other folks here used the 225/55 size, I went to Tire Rack and was fully prepared to get some Goodyear Eagle HPs. After looking at the reviews for those and others, instead I went with the Bridgestone RE-950s as a better compromise. They are a great deal at $456 delivered.
Indeed, I got a call from Tire Rack asking me if I was sure they would fit as they did not have much experience with other 16" sizes on the TL. The 225s are EXACTLY the same height as the 205/60s and not radically wider. It seems that most problems experienced with rubbin' occur with aftermarket wheels that are either much wider and/or have an improper offset.
rw
Old 10-09-2002 | 08:55 PM
KJ32's Avatar
If we jump from 205 to 225 on stock 16" rim, will it spill out alot? Can you post any pic?
Old 10-09-2002 | 09:31 PM
Tatewaki's Avatar
I have 215/55 on my stock 16" rims. I was going to go for 225/55 but first the shop refused to install for me. And second, after I have the 215/55 on my car, it's already very close to rubbing. My car is lowered with H&R sports. If I have had 225/55, I might get some rubbing problems. I know the speedo is off, but the shorter profile looks quite good with the drop.
Tatewaki
Old 10-09-2002 | 09:44 PM
SilverUA5's Avatar
I was the one that sent you the message. Thanks for getting back and if you don't mind, please post some pics. BTW, I'm not Don(?).
Old 10-09-2002 | 09:51 PM
unbeknownst's Avatar
The RE950's are GREAT tires. I had them on my last car.... they comapre to many Z-rated tires in terms of grip. Good choice.
Old 10-10-2002 | 04:52 PM
mskeen's Avatar
Question
Anybody with 225/55's have the inside of there tire wearing faster?
My car isn't dropped but my car seems to be going through tires like it has a camber problem. I think I'll try some Yokohama DB next but I don't want all 225/55 to wear like my Kumho's did.
Old 10-10-2002 | 07:08 PM
SilverUA5's Avatar
You need an alignment. I don't think it's your tires.
Old 10-10-2002 | 08:30 PM
fsttyms1's Avatar
i have 225-50 no rubbing what so ever. my tires were wearing on the inside pretty quick also but i had an alignment done to correct the toe out, it would take alot of negative camber to equal a little toe out
Old 10-12-2002 | 01:16 AM
KJ32's Avatar
Could it be the sidewall is spilling out so much and the natural movement of suspension that goes to (-) as it compresses? I want some beefier tires, but I don't want aftermath like that.
Old 10-14-2002 | 12:24 PM
sparky57's Avatar
Sorry guys, I've been out of town for a while. Here are some pics:
I think 225/55s are the best overall compromise in size. They have the same diameter as the 205/60s and by using the stock 16" wheels, it avoids the horsepower loss of going to 18s or larger.
rw
Old 10-14-2002 | 02:16 PM
SilverUA5's Avatar
rw [/B]
Does the inside wear out as fast as others are saying???
Old 10-14-2002 | 08:25 PM
KJ32's Avatar
Also someone mentioned the shop refused to mount 225 on 16x6.5 stock rims because it's not safe.
Old 10-15-2002 | 05:20 AM
Lawaia's Avatar
Moderator Alumnus
225/55-16 will fit just fine on a 6.5" wheel. In fact most manufacturers spec wheel widths of 6-8" for this size tire.
Old 10-15-2002 | 09:35 PM
sparky57's Avatar
As Dirty Harry noted long ago, "A man has to know his limitations." Here we have a case of local incompetence. Note the factory recommendation is for a rim of 6 to 8 inches.
http://www.bridgestonetire.com/dpp/s...sproductid=228
rw
Old 05-02-2007 | 05:49 AM
wowwy1's Avatar
Sparky - can't open the pics as the link is expired...can you repost, or is there another location to see the 225 55 16's?
ssjkev16
03-08-2020 08:17 PM
bailey24
11-21-2015 08:43 PM
handsom-hustla
11-13-2015 05:04 PM
bailey24
08-31-2015 05:38 PM
Quick Reply: 225/55s on stock rims don't rub (response to private email)
