10MM spacers on Backwheels of 3G TL
I was thinking about bumping out my rear wheels 10mm. I found a good deal on these
Kics Wheel Spacer - 10mm / 12x1.5mm / 5 x 114.3
centerbore 67mm
I assume these will fit the TL without hubcentric rings?
Any thoughts or opinions on doing this?
centerbore 67mm
I think our cars are 64.1MM centerbore.
But I don't know for sure.
I don't think you want 3MM of play if I'm right.
If you ever plan on lowering, or are lowered I wouldn't recommend spacers because it will take away that gap you might need to adjust your negative camber.
Well, let me elaborate.
I have 245 tires...and no camber kit...on my 8.5" Aspecs. I barely have any room between the fender and the top of the tire to begin with. With a spacer I would probably rub and there's def. not a lot of room to get a camber kit to bring the top part of the tire back out like when you're adding positive camber.
The spacers will give a lot of vibration at certain speeds if it's not hubcentric so I would personally get the Kics spacer hubcentric ring as well. I think it's an additional $30 or so. It'll center the spacer perfectly and you won't get any vibrations after.
IBankMouse
06-13-2020 12:53 PM
