100 lb. too much torque on lug nuts?
I have an 06 TL and just got my winter tires put on.
My cousin and I didn't know what amount of torque to apply to the lug nuts so we tightened each lug nut at to 100lb.
100lb is basically the torque # for a Honda Civic so we went by that #.
I have been reading many threads where people or torquing their lug nuts to 80lb.
Is 100 too much? Should I release some of the torque?
Thanks.
Thanks.
Thanks.
Thanks.
Torque requirement is based on bolt size and ours is 12 MM and as far as the Civic goes I don't think 100 ft/lb is right if it is stock. Even a VW which has 14 MM studs only uses 89 .
Hardware Bolt or Stud Size Typical Torque Range
Ft/Lbs
12 x 1.5 mm 70 - 80
12 x 1.25 mm 70 - 80
14 x 1.5 mm 85 - 90
14 x 1.25 mm 85 - 90
Ft/Lbs
12 x 1.5 mm 70 - 80
14 x 1.5 mm 85 - 90
honestly, I know A LOT of people/shops who go over 80 and never had a problem, but if you want to do it RIGHT, use a torque wrench at 80. I used to just use my breaker bar and tighten firmly, was always fine, but once you start using a torque wrench, you cant go back to guessing method with a breaker bar.
Torque spec is specified not only so the nuts/bolts are not under tightened but also over tightened for their size and stressed. Over torqueing is not fine. Your not just dealing with warped rotors worse your .. possible failing studs.
I have had 25 cars and always torqued my lugs on all of them to 90 ft lbs and never had a lug fail. 100 is fine, next time you take you wheels off just lower it a bit.
Subaru's are also supposed to be 80 and I do them at 100. I've done thousands like this with zero issues. People who are worried are just worriers. I will say I have replaced studs from guys who I know excessively jam on lugs with the 1/2" gun or even jam them on with a gun then use a 1' long breaker bar after.
neuronbob
23
07-16-2019 10:48 AM
