06 TPMS replacement question...
Old Jan 8, 2018 | 09:29 AM
TheSauceBoss's Avatar
I searched around for threads but if this has already been discussed I apologize.
For about 3 months now, my front pass. side TPMS has been showing and incorrect 59 PSI while the rest show the correct ~30 psi.
After 10 or so minutes of driving, I get the "check TPMS" system error for the rest of the trip. Rinse and repeat every time I drive somewhere.
If I replace the (assumed) faulty front-right sensor, does anyone know if it will fix the overall system error? The dash notifications every single time I drive anywhere are driving me crazy.
Any input would be appreciated
Looking at this one, for the record...
Amazon Amazon
Old Jan 10, 2018 | 05:50 AM
NetGnome's Avatar
I had a similar issue and replacing the sensor fixed the problem.
I purchased a similar looking tpms sensor but the tire dealer could not get it to sync with the display.
So I purchased the more expensive tpms sensor from the tire dealer and that is working fine.
Old Jan 11, 2018 | 12:19 PM
Hey thanks,
Do you know if the first one you bought was a true OEM sensor? Or was it aftermarket?
Based on my research so far it appears that it can take a half hour or so for the sensors to sync up, so hopefully you didn't get taken for a ride by that dealer!
Doc Alejo
Jan 12, 2013 01:16 PM
JustinZ
Sep 9, 2009 07:45 AM
clintner07
Nov 14, 2008 07:25 PM
davidpham
Aug 28, 2008 09:10 PM
