Replacement rim, tpms question
Old Nov 14, 2008 | 05:03 PM
clintner07's Avatar
8th Gear
I have a bent rim on my 2007 TL, so I managed to get a replacement rim with no sensor. Can the old sensor be reused? If so can a independent tire shop handle it? Or am I better of buying a new sensor put it in the rim myself?
Old Nov 14, 2008 | 07:25 PM
rodneyc77's Avatar
Retired!!! ON TOP!!!
yes the old sensors work...
The tire shop should have no issues transfering them for you... However... You should buy the outer valve and rubber seal service parts cause they are designed for one time sealing use... It costs like $15 at the dealer... This will guarantee a tight seal on the replacement wheel valve opening hole...
Good luck...
rseb4agze
May 3, 2016 07:41 AM
booma1218
May 3, 2016 07:39 AM
bailey24
Nov 21, 2015 08:43 PM
lland
Oct 4, 2015 04:47 PM
bailey24
Aug 31, 2015 05:38 PM
