Yet another problem with my TL engine won't turn over.
I'm really starting to regret my purchase. I have had many problems with my TL since I bought it. luckily most were covered under warranty. Now that its out of warranty I have had three more issues, cruise control switch failed, another dying battery and now my car won't start. I tried to start my car today and the engine would not turn over, it started fine yesterday other than being slow to turn over. I already knew the battery needed replacement, so I changed that about an hour ago, but still the engine will not turn over.
Any ideas on what the issue is now?
all seems fine now
after searching the threads I followed another guys steps and got it started. I tightened the terminal connections on the new battery, and while I was starting it I just gave a couple of pumps with the gas pedal and it started right up. I tried again this morning and it started up fine again (without having to give it gas). I have no idea what the problem could have been. I think your fuel pump suggestion seems possible. The terminal connections were already pretty tight though I was able to turn the bolts pretty easily. And even then it still wouldn't start the first time until I gave it gas. But now it starts up fine without having to do that.
The only thing I noticed now is a slight strange smell, but not sure what it could be, I took it to the dealer first thing this morning, but they didn't find anything related to the problem. I'll keep an eye on it.
if you want to do a cold start you turn the car on, press the pedal to the floor for about a second, release and start the car. Doing that tells the ECM to do a cold start
yeah, look in your manual it tells you how to do it.
I lost my manual
I was pretty good about keeping in my glove box; but as soon as I took it into the house to read through it, I never got around to putting it back in the car.
HeloDown
09-08-2015 06:51 PM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
