XM sounds like crap
Old Mar 18, 2007 | 12:46 AM
Grinch80's Avatar
XM sounds like crap
XM sounds muffled, all low/mid range, no high end. Sounds like it cuts out at 12-14 kHz. Under the same EQ settings, all other inputs sound fine.
Any ideas?
Old Mar 18, 2007 | 01:08 AM
wasupdog's Avatar
My Garage not
yea, this is the "problems and fixes" sub-forum and yea, this is a problem. no, there is no fix other than adjusting the eq on the stereo unit.
Old Mar 18, 2007 | 01:49 AM
Grinch80's Avatar
That's clear enough, thanks. I'm not all that impressed with XM programming (except for O&A), and with the crappy sound, it's a no-brainer for me not to continue my 3 month promo.
Old Mar 19, 2007 | 05:26 PM
KeithL's Avatar
Welcome to XM, I had Sirius for a while and found their sound quality to be somewhat better, cleaner and clearer, unfortunatley their signal sucked and I woudl get drop out all the time.
Old Mar 19, 2007 | 05:36 PM
dampfnudel's Avatar
It's definitely not worth the "regular" price. Maybe HD radio will be better.
Old Mar 19, 2007 | 09:04 PM
Grinch80's Avatar
You guys have probably been over this already, but...
I did some digging and it appears XM is severly bandwidth limited. Quantity over quality I suppose.
Since XM doesn't publish its bitrates, most folks are speculating 48-96 kbps per channel (good enough for spoken broadcasts, certainly not for music). And I don't care how good the compression is at these bitrates.
So I tested with my iPod over AUX. Even 128 kbps sounded a tad muffled, whereas 192 kbps sounded great. Both of my tests employed AAC; no idea what compression XM uses.
All subjective of course, but I still can't get over how bad XM actually sounds. No wonder why its merging to stay alive...if the fidelity was high, you'd have audiophiles flocking to pay $13/month.
I'm just glad, as a new owner, that it's not my TL at fault.
Old Mar 19, 2007 | 09:16 PM
Grinch80's Avatar
P.S. I could not tell a difference between 192 AAC and lossless with the stock TL stereo. Which is good since I only have 8GB storage (less actually) with my nano.
mlody
Dec 4, 2019 02:11 PM
DerrickW
Nov 15, 2015 05:52 PM
blacktsxwagon
Oct 27, 2015 10:12 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
hashbrown
Sep 29, 2015 12:13 PM
