Wtf??!!
Old Jun 11, 2015 | 06:31 PM
I Wanna Go Fast's Avatar
Wtf??!!
Got my car back yesterday for a rebuilt tranny and decided to do a random scan with my scanner and these codes popped up. So i cleared them and now the VSA light and the yellow triangle with the exclamation point inside of it are both on. What the hell is up with that??
Old Jun 11, 2015 | 07:25 PM
erdoc48's Avatar
06 Anthracite TL
Hate to say it, but the best course of action is to take it back to where the trany was installed and let them deal with it. It's up to the installer to make it all right. Also, how old is your battery? If it's on the way out, it could cause some issues (although I'm sure not all as above).
Old Jun 11, 2015 | 08:49 PM
polish_pat's Avatar
Seems like they forgot to plug back some electrical switch(es). I would def bring it back ASAP especially if still have issues after clearing codes...i have also checked the codes on the ecu after some repairs and i found that sometimes a repair shop doesn't clear the codes that might have poped up during the testing phase...but the fact that the car still shows distress after clearing codes means there is something wrong
Old Jun 11, 2015 | 09:27 PM
the weird part is that the lights came on after I cleared the codes...anyway will give the shop a call tomorrow
Cant go back there its a 2hr drive one way..smh
Old Jun 12, 2015 | 12:23 AM
nfnsquared's Avatar
Quite likely just a bad battery....
Old Jun 12, 2015 | 07:12 AM
GRK's Avatar
GRK
Maybe a bad ground
Old Jun 13, 2015 | 10:55 AM
truonghthe's Avatar
looks like someone forgot to plug in all the connection plug.
Old Jul 15, 2015 | 10:09 PM
i read somewhere here on the forum that there is a reset so i'm going to try hopefully it weekend if my headlights work properly
i say reset because now i'm gettin an 84-1 code
Old Jul 17, 2015 | 10:36 PM
I hate cars's Avatar
Yep. Usually when you have a low voltage code along with several seemingly unrelated codes it's the battery or connections.
Since the trans was just replaced, it could be a ground. I would begin by checking the battery cables.
Old Jul 18, 2015 | 12:05 PM
just noticed the side motor mount(with the engine ground) bolts broke
Old Aug 1, 2015 | 05:31 AM
Got the side mount replaced yesterday so the engine is all good and most codes cleared except for a code refering to some sort of logic. I forgot to write it down. I'm sure the yellow triangle will pop up again. I'll pull code and poat
Rapture
Oct 4, 2015 12:05 AM
E92Vancouver
3G MDX (2014-2020)
Sep 21, 2015 02:32 PM
iCrap
Sep 11, 2015 06:21 PM
ahsm
Sep 9, 2015 08:35 AM
