Won't Stay Up...
Old Dec 4, 2010 | 02:42 PM
77donovan77's Avatar
....just dancing in
Won't Stay Up...
Hey guys, sure this may have happened or it will happen to you. But my hood all at once won't stay up. Any solutions? ....and the little blue pill is out of the question
Old Dec 4, 2010 | 03:18 PM
guitarplayer16's Avatar
Might just need to new hood dampers.
74145-SEP-A01
74149-SEP-A01
Old Dec 4, 2010 | 03:22 PM
....just dancing in
Thanks....I am now looking into that.
Old Dec 5, 2010 | 12:30 PM
jr27's Avatar
2005 AM at/navi
i just noticed this happen to mine. but it was funny because i was parked in reverse on the drive way and when i openned the hood it wont stay up. it does stay up on if im on flat ground or if im facing the garage door on the drive way. i guess the weight of the hood when facing downwards is too much for the 5 year old dampers.
Old Dec 5, 2010 | 01:07 PM
....just dancing in
First I thought I was losing my mind when I knew it was up while I was changing the oil, when inside the house, come back and the hood was down. I am having almost the same problem with the trunk, it won't open high enough when you press the release button, but it will stay up.....go figure.
Old Dec 5, 2010 | 01:40 PM
Wait, the trunk doesn't have dampers =P
The trunk button doesn't open the trunk, it just pops it, then you have to open it yourself.
Old Dec 5, 2010 | 02:01 PM
....just dancing in
Yes I know, before the release button would allowed the trunk to completely disengage from the latch leaving a half inch to one inch opening. Now you wouldn't notice if the trunk has open......
Old Dec 5, 2010 | 02:34 PM
Maybe trunk popper going bad? =(
Old Dec 7, 2010 | 04:20 PM
Majofo's Avatar
Give it some Viagra, two pills in the tank and two in the motor.
Old Dec 7, 2010 | 04:41 PM
x2, title is misleading!!!!
Old Dec 7, 2010 | 04:42 PM
AMUA6's Avatar
ScoobyZINE
Maybe I can help
Old Dec 7, 2010 | 09:14 PM
....just dancing in
Originally Posted by AMUA6
Maybe I can help
you're one sick puppy
Old Mar 13, 2013 | 01:30 AM
GSW510's Avatar
5th Gear
I just bought my 2G TL and I have the same problem. Glad its not more complicated to fix
Old Mar 13, 2013 | 09:52 AM
Project 04TL's Avatar
check the garage, there is a diy on this if you really need it.
this is one of the easiest parts you can change, if it takes more than a minute for both sides you are doing it wrong.
Old Mar 14, 2013 | 10:06 AM
cipdagr3at's Avatar
HASTA LA VICTORIA'
Try ebay.. I found some dampers for 35.00 free shipping
Old Mar 14, 2013 | 06:00 PM
DMZ's Avatar
DMZ
Head a da Family
Check out rockauto.com.
Under Body Exterior, look for Lift Supports
They have them for about $14 each.
Old Mar 14, 2013 | 06:03 PM
pohljm's Avatar
I just got my replacements at oreilly, it was 19.00 i believe. you only really need one.
Old Mar 14, 2013 | 06:58 PM
Adobeman's Avatar
The DVD-A Script Guy
I used to just clamp a vise grip to the worn out dampers on my Saab 900 to keep the hatchback open. Any damage it did to the smooth (chromed) finish of the slides didn't matter since it was shot anyway. That was appropriate for a quirky Swedish car. For the TL I'd get the new dampers for sure.
Fool
Mar 10, 2016 08:42 PM
Oakroadsteve
Oct 28, 2015 10:28 PM
hashbrown
Sep 29, 2015 12:13 PM
