Wobbling Shift Knob!
Old Oct 26, 2005 | 11:39 AM
stavebomb's Avatar
My shift knob has gotten to the point where it is almost unbarable. It is so annoying! When I first got the car it was nice and stiff and over then 6 months or so that I have had it, it has become really loose. Does anybody know how to fix this?
Old Oct 26, 2005 | 12:45 PM
TLTrance's Avatar
AVB for President!
I think the first place to go is to the dealers.. Something's probably loose or cracked... Warranty work, definitely.
Old Oct 26, 2005 | 01:40 PM
Thorin78's Avatar
Previous Owner
Yeah, it may be covered under warranty to get them to fix it.
If they make you buy a new one, I've got one that's had less than 18000 miles on it that I switched out when I bought the new razo shift knob.
actually, this gives you perfect reason to buy a new shift knob.
Old Oct 26, 2005 | 02:07 PM
Scribesoft's Avatar
Aaaarrrggghhhh!
I'm assuming you already tried turning it clockwise all the way?
What happens when you get to the end? does it just keep spinning w/o ever tightening?
EDIT: That's if it's a 6MT ^
If it's an AT, I'm assuming there's a set screw you could easily tighten (may be hidden, but dig around and you'll find it)
Old Oct 28, 2005 | 02:29 AM
hcekc's Avatar
There's no set screw in the AT's shift knob.
Have you been tightening the knob? One extra full turn will strip the "plastic" threads inside the knob. Remove knob by turning counter clockwise and look at the threads. Maybe hard to see though as the threads are way in. You can try loctite, but this is somewhat permanent and no guarantee that it will work. Best bet would be to take Thorin78's offer or just buy a new aftermarket knob. Good luck.
Old Oct 28, 2005 | 11:40 AM
stavebomb's Avatar
Ohhh hold on a second. I'm sorry. I phrased that terribly. Its not the actuall knob it is the entire stick that wobbles. I was wondering if there is any screws underneath the boot if I were to remove it to tighten it.
Old Oct 28, 2005 | 12:22 PM
Scribesoft's Avatar
Aaaarrrggghhhh!
Are we talking about AT or MT here? I'm assuming MT as you mentioned the boot. Is that correct?
Old Nov 1, 2005 | 01:29 PM
stavebomb's Avatar
Manual.
SidhuSaaB
May 30, 2020 12:40 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
Popee
Dec 20, 2015 12:08 AM
mellsonnj
Sep 24, 2015 04:42 PM
Hines57
Sep 24, 2015 01:58 PM
