Winsheild sprayers
Old Feb 20, 2012 | 05:18 PM
krink1490's Avatar
Winsheild sprayers
so my winsheild sprayers stopped working like a month ago thought i was out of fluid so i bought fluid last night filled up the tank still wont spray it was really cold last night so i thought maybe the lines were frozen it was about 50 degrees today here in jersey and still nothing i dont even hear them spraying what could be the issue
Old Feb 20, 2012 | 05:29 PM
guitarplayer16's Avatar
Is your dimming rear mirror light out too?
If so, you probably blew the fuse.
Check fuse #20 under the dash.
Replace with 10A fuse.
Old Feb 20, 2012 | 05:30 PM
jokerman826's Avatar
Jokerman
check the fuse first, if the fuse is good then most likely its the washer fluid motor. Most likely its the fuse though.
Old Feb 20, 2012 | 05:36 PM
krink1490's Avatar
yes the light is out
Old Feb 20, 2012 | 05:38 PM
There you go, buy a 10A mini fuse and replace the fuse #20 under the dash by your left foot.
Problem fixed.
I had it happen last year.
What happened was you flicked on your wipers when they were frozen so the fuse blew.
Old Feb 20, 2012 | 06:49 PM
krink1490's Avatar
will my fucking mirror work too lol cuz that shit doesnt work either
Old Feb 20, 2012 | 07:50 PM
Yes, your side mirrors will work too!
It's all on the fuse #20 so replace that fuse and it will solve like 5 things lol
Old Feb 20, 2012 | 07:52 PM
krink1490's Avatar
cuz right now my mirrors dont work neither do my memory seats my rear view mirror doesnt dim and the light isnt on either lol
Old Feb 20, 2012 | 07:54 PM
Are you gonna replace the fuse #20 or not?
It WILL solve your problem.
No problem...
Old Feb 20, 2012 | 07:55 PM
krink1490's Avatar
lol alright thanks where can i get one ....autozone or something?
Old Feb 20, 2012 | 08:04 PM
honda_nut's Avatar
2024 Genesis G70 3.3T
Yes, any auto place should have it. It's a mini 10A fuse.
Also, they reason why it blew was because the washer fluid was frozen when you tried to use them. DONT MIX WATER WITH THE WINDSIELD WASHER FLUID OR USE CHEAP FLUID.
Old Feb 20, 2012 | 08:08 PM
krink1490's Avatar
alright thanks yea i just bought the car about 2 months ago so someone must have used water or something hopefully this solves my issue
Old Feb 20, 2012 | 11:30 PM
Will Y.'s Avatar
Registered but harmless
The TSB specifies replacement of the 7.5 amp fuse with a 10 amp fuse.
BTW, there should already be extra fuses in the car's fuse box.
FWIW, there are special formulations of windshield washer fluid used in places with below-freezing temps which should be used in cold weather.
In coastal SoCal and NorCal, it's difficult to find anything other than the standard 32F*+ windshield washer fluid, which will freeze overnight at colder temps.
Old Feb 22, 2012 | 05:36 PM
krink1490's Avatar
yo guitarplayer thanks bro i went to autozone today got that fuse for my sprayers it fixed that my rear view mirror my side mirrors and my seats im fucking pumped lol thanks bro
SweetJazz
Wash & Wax
24
Mar 9, 2008 09:24 PM
jayinnj
1G CL Problems & Fixes
Mar 12, 2007 06:57 PM
campIIIMAF
Dec 2, 2004 09:00 AM
DIVA
Jun 25, 2002 10:50 AM
99AcTl
Nov 30, 2001 11:21 AM
