Window Won't Roll Up
Old Jun 3, 2009 | 09:55 PM
narnia's Avatar
Team SSM Queen
I can open my front passenger window, but it doesn't want to close. When I hit the button, it goes up a few inches then drops back down again. It takes a lot of tries to get it all the way up. Has anyone else had this happen?
It's an '04 so out of warranty - but I'm not complaining. This is the first problem I've had with my car, not even a rattle, and I have almost 80,000 miles on it.
Old Jun 4, 2009 | 08:37 AM
Majofo's Avatar
check the door sill runners and remove the panel to check for any blockage in the glass channels, if the window encounters too much stress / resistance it'll go down to protect itself and protect you from you getting your finger caught while it's going up.. so basically there is too much resistance.. try to look for anything that may be hanging it up and maybe use channel grease, otherwise the sensor might be malfunctioning but doubt it.
Old Jun 4, 2009 | 11:27 AM
woot427's Avatar
maybe this:
http://www.in.honda.com/Rjanisis/pubs/SB/B06-031.PDF
Old Jun 4, 2009 | 12:25 PM
narnia's Avatar
Team SSM Queen
Thanks! woot427 that's really helpful, esp. the part that says -
Out of warranty: Any repair performed after warranty expiration may be eligible for goodwill consideration by the District Parts and Service Manager or your Zone Office. You must request consideration, and get a decision, before starting work.
Old Jun 4, 2009 | 08:00 PM
LoveMyTL-S's Avatar
You may need to grease the window regulator.....
Jul 16, 2017 07:33 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
