Window trim clear coat fix
Old May 24, 2021 | 02:54 PM
Caleb Robinson's Avatar
7th Gear
I wanna restore the look of the gloss window trim on my tl any ideas either diy or if they make covers or something for these.. I was thinking about sanding the clear coat down in that area and just recoating the clear coat? Thank you so much in advance.
Old May 24, 2021 | 05:22 PM
I believe this is what you're looking for..
https://acurazine.com/forums/third-g...w-trim-904516/
Old May 24, 2021 | 05:23 PM
csmeance's Avatar
The trim is coated in vinyl wrap and you can rewrap them yourself. I've done it and there are DIY threads here on how to do it. I used 3M vinyl from amazon; use a heat gun and the old film will peel very easily. No heat and you'll struggle a lot with it.
jimmyfu
Mar 18, 2015 10:13 AM
UA6
Norcal
Nov 8, 2013 11:28 AM
doubledeala
Jul 24, 2007 06:17 PM
mrpeeng
Aug 16, 2006 02:18 PM
