Window stops going up
Old Jun 2, 2011 | 11:05 AM
ncabeceiras's Avatar
Hey guys hoping someone can help me out...my driverside window no longer goes all the way up on its own. If the window is down halfway it'll go up but when i put the window alll the way down and try to put it up it stop about 3/4 of the way up...and the times it may go all the way up it go up and then come back down a bit... Any suggestions????????
Old Jun 2, 2011 | 12:54 PM
dwb993's Avatar
Thats normal---its a safety feature to prevent catching hands/heads/whatever in the window.
You have to reset it. The Owner's Manual has instructions:
1. Roll window down by keeping your finger fully depressed on the switch. Keep your finger fully depressed on the switch for 2 full seconds after the window is completely down.
2. Repeat above when rolling the window up. Hold window switch in the fully-up position for 2-seconds after it's fully closed.
Problem should be solved. However, it will return periodically.
Just continue to repeat the above steps when this happens.
EDIT: Thanks to nfnsquared for these instructions in another thread. Also, OP a search of "Auto Window" would have turned up a ton of threads on this issue.
Old Jun 3, 2011 | 11:18 AM
cool man thanks alot. thats what it was we back in business
Old Jun 3, 2011 | 12:30 PM
dwb993's Avatar
MrHeeltoe
20
Feb 23, 2023 01:54 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
