Window stops going up
Old Jun 2, 2011 | 11:04 AM
ncabeceiras's Avatar
Hey guys hoping someone can help me out...my driverside window no longer goes all the way up on its own. If the window is down halfway it'll go up but when i put the window alll the way down and try to put it up it stop about 3/4 of the way up...and the times it may go all the way up it go up and then come back down a bit... Any suggestions????????
Old Jun 4, 2011 | 09:07 PM
jda123's Avatar
Dogmatic Dinosaur
Go and get some Shin-Etsu grease (around $15) from an Acura or Honda dealer. Take a towel in a flat-head screwdriver and clean out the back groove of the window. Once it is clean, then put a nice layer of Shin-Etsu on there to lube it up. Put the window up and down a couple of times and it should be better. Worked on both of my TLs.
If it is really bad, then take the door panel off and lube up the tracks.
If neither of these things work, post... you might need some new parts and we can help you out.
This is the same grease that you can use for your sunroof tracks and lots of other things.
Old Jun 4, 2011 | 09:10 PM
greddycl-s01's Avatar
quick fix for free is to stop the window before it gets to the 3/4 mark and then hit it up again...it should go all the way up
MrHeeltoe
20
Feb 23, 2023 01:54 PM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
MrHeeltoe
Sep 29, 2015 10:43 PM
MrHeeltoe
Sep 28, 2015 05:43 PM
