Window Regulator '08 Base
Old Sep 29, 2014 | 12:14 PM
cammark35's Avatar
I have a lot of experience with Honda and Acura maintenance and repair. However this CAN-BUS thing is new to me.
I've got a stubborn window regulator on my wife's 2008 TL base. Front passenger window would work intermittently for a few months. now it will not roll down at all. I can hear a relay-click sound when I try the switch. #26 fuse is good.
So before I continue my normal diagnostic routine (expecting to replace the regulator/motor or find a loose wire) will I really need to run a reset procedure on the power window system every time I disconnect power or replace a component? This is what I'm reading in my FSM.
On the topic of resetting the system(s), is there still no affordable solution or alternative to the HDS for the home mechanic? $700 for software alone is pretty discouraging.
le^2
Mar 17, 2026 05:06 AM
Jul 16, 2017 07:33 AM
iRaw
ILX Photograph Gallery
30
Aug 5, 2016 04:41 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
xsilverhawkx
Sep 28, 2015 06:51 PM
