Wierd odor
Old Jan 5, 2011 | 05:58 PM
boyhamdzui's Avatar
BMW 535i
Wierd odor
When I run A/C or just fan , there are no odor. But while the A/C is on and I turn it off , immediately I smell a weird odor , I don't know how to describe it . It appears for short amount of time ( 10-15 minutes ) then go away. I just changed my air filter last 3 week. Anyone has this issue ?
Old Jan 5, 2011 | 06:15 PM
Pantyfish's Avatar
can you elaborate on the order smell? does it smell like moldy water?
Old Jan 5, 2011 | 06:16 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Did you change your engine air filter or your cabin air filter?
Old Jan 5, 2011 | 07:12 PM
boyhamdzui's Avatar
BMW 535i
I did change the cabin air filter ( sorry it's cabin air filter not air filter like what I said ) but not yet the air filter. It smells somehow like mold.
Old Jan 5, 2011 | 07:27 PM
Spray Lysol into all of your interior vents. Start your car, turn your fan on, and spray Lysol into all of the vents that are underneath the hood right below the wipers.
Try it and see if it works.
Old Jan 6, 2011 | 01:12 PM
vuuha05's Avatar
Febreze that mofo up! And possibly buy those air freshener clips for the vents. That's my cheap method to fix the odor
Old Jan 6, 2011 | 01:32 PM
this.
Old Jan 6, 2011 | 03:59 PM
Majofo's Avatar
There's another spray that works better.. I forgot though..
Old Jan 6, 2011 | 05:14 PM
SouthernBoy's Avatar
Registered Member
The most common cause of this is; 1) running your A/C in recirculate mode most of the time, and 2) not turning off your A/C before you arrive at your destination after having used it for a bit.
About three to five minutes before you get to where you're going when using your A/C, turn it off then set your fan speed on the highest setting. This will help dry out the evaporator. Also, try to avoid using the recirculate mode too much. I know that when using the AUTO setting, this is what you get initially because the car is going to try to cool down the cabin quickly. Just watch it.
Most important is turning it off before you get to where you are going and running the fan on high speed.
Old Jan 6, 2011 | 08:59 PM
boyhamdzui's Avatar
BMW 535i
I thought I'm in both 1 and 2 . Is there not anyway than doing it every time ?
I did try the Lysol like you guys said yesterday. Up to now , it seems better. I did it before but leave the fan like 2-3 minutes ( no result ). But yesterday I turned the fan high for really long time.
Old Jan 6, 2011 | 09:41 PM
Registered Member
Not sure what you mean by this.
Old Jan 6, 2011 | 09:49 PM
boyhamdzui's Avatar
BMW 535i
I mean I did run your A/C in recirculate mode most of the time and not turning off your A/C before you arrive at your destination after having used it for a bit
Old Jan 7, 2011 | 08:41 AM
sprousa's Avatar
I have the same issue. I think it also happens if the car was smoked in. The smoke gets stuck to the A/C Coils inside the cabin.
There is a specific spray you can use to clean out the smell. Used car dealers use it but I can't recall the name.
I wouldn't use Lysol because it leaves a residue/film on wherever you spray it.
If you dont drive around with recirculate on the cabin filter is going to get very dirty very fast.
I was fixing a sqeek once inside my dash and decided to check my cabin filter. Well I left it out when I drove to the store to get a new filter. The air coming into the car from the outside with the glove compartment off was greater at 30 mph then having all the windows down at 70mph without recirculate on.
Old Jan 7, 2011 | 08:44 AM
nfnsquared's Avatar
Originally Posted by sprousa
...There is a specific spray you can use to clean out the smell. Used car dealers use it but I can't recall the name....
Originally Posted by Majofo
...There's another spray that works better.. I forgot though...
Let us know if you remember it later. Would be nice to file away just in case...
Old Jan 9, 2011 | 09:17 AM
4g63gsx's Avatar
9th Gear
Let us know what works best, mine is starting to do the same!
Old Jan 9, 2011 | 12:01 PM
Will Y.'s Avatar
Registered but harmless
Was it the "Ozium"-brand spray?
Old Jan 9, 2011 | 03:12 PM
cjTL's Avatar
I'm Craig
If it smells like mold, chances are there is mold, and you most likely wouldn't want to just cover it up with Frebreeze. Let us know if it goes away.
DetroitCL-S
Wash & Wax
Oct 25, 2004 06:49 PM
stejus
Mar 23, 2004 07:57 AM
