Whinning Noise from Engine Bay
Old Jul 21, 2014 | 10:59 AM
Gwaks's Avatar
Hey everyone, I have an 04 TL with 113K. I've tried researching this for a while now and haven't found exactly what I was looking for. My car recently started to make a "Supercharger" like sound from the drive belt area of my engine. It makes this whinning noise at idle and gets louder as the RPMS go up. Doesn't matter if the A/C is on or not, I turn the steering wheel and the sound stays the same. I did my timing belt service at 95K, and replaced most pulleys except the tensioner pulley. I went to Advance Auto and got the part, replaced it and the noise is still there. I'm now looking into my alternator as a suspect. I hear people discuss the pulley or bearing on it. Can anyone provide the part number or exactly what I need to get? I also did the test where you place a metal piece and put your ear up to certain parts and the noise is louder in the tensioner area.
What I'm asking is, can I replace just the pulley or bearing on my alternator and where can I find the part? Thanks.
Old Jul 21, 2014 | 11:10 AM
the_tl_man09's Avatar
do you have a dmm? if so check your volts with all you electronics turned on and see how your volts are. my altenator whined when it went out the first time. i replaced it with a autozone altenator and that one went out, didnt even have it 2 months. if it does turn out to be your altenator i recommend to not skimp and just go with the oem from the dealer..more expensive but hey it wont fuck up in 2 months like mine did
Old Jul 21, 2014 | 11:13 AM
Gwaks's Avatar
No, I don't. But I can take it to an Advance Auto Parts and check my volts there, correct? But definitely, OEM is usually the way to go, ha.
Old Jul 21, 2014 | 11:45 AM
have you experienced any odd eletrical symptoms or a brunign smell from the engine that smells like burning electronics
Old Jul 21, 2014 | 12:14 PM
truonghthe's Avatar
if the alternator is the main cause of the noise you have to replace the whole alternator.
Old Jul 21, 2014 | 08:11 PM
Gwaks's Avatar
Yes, my car hasn't been starting for about 3 months now. And when I say not starting, I mean it takes me anywhere from 2-20 tries for my car to start. I get a buzzing noise coming from a relay by my fuse box. Bought a brand new starter and that didn't help at all. Before I even bought that new starter got my battery, alternator and starter checked and everything checked out. This was back when my car still wasn't starting, and that was a while ago. My car doesn't turn over, you can just hear a electrical type noise, not the rapid dead battery noise.
Other than that, there is no weird issues with electrical stuff.
Old Jul 21, 2014 | 08:12 PM
Gwaks's Avatar
Thanks for the feedback, man.
Old Jul 22, 2014 | 08:42 PM
revolutn's Avatar
Out of curiosity did / does it sound at all like this:
youtu.be\oML639NhiWs
Old Jul 22, 2014 | 10:15 PM
Gwaks's Avatar
No, not at all. I'll try to post my video on here.
Old Jul 22, 2014 | 10:19 PM
Gwaks's Avatar
Here's a video I took of the sound. Currently at 113K, I replaced the Idler pulley at 95K when I did my timing belt service. I went to Advance Auto Parts two days ago and got a tensioner pulley, and that wasn't the issue. That belt was also replaced at 95K. All OEM, except the tensioner pulley I just purchased. I'm looking at my alternator next. Anyone have anymore suggestions or input? Thanks! This is very irritating.
Old Jul 24, 2014 | 02:33 AM
E DOUBLES TL's Avatar
I had that same noise start over the weekend on my 07 TL @ 94k and took it to the shop today and it's the alternator its failing so i'm getting a new one installed ill have my car back tomorrow will see if the noise is completely gone. I also had the timing belt, tensioners and water pump changed like 5 months ago also. Since my tensioners were making noise.
Old Aug 17, 2014 | 07:25 PM
BigCoachT's Avatar
Whining noise in my 1999 3.5RL
I have that same noise even after I changed my alternator. What ends should I do?
Iakonafuji
Sep 21, 2015 02:39 PM
Caddy
1G RDX (2007-2012)
Sep 18, 2015 12:44 PM
jblessing
Wash & Wax
Sep 17, 2015 09:28 PM
iCrap
Sep 11, 2015 06:21 PM
whitesoxsfan12
Sep 7, 2015 04:07 PM
