Where is the outside thermometer/temperature sensor located?
Old Aug 6, 2008 | 12:50 AM
shubysingh's Avatar
Ive been having a problem, its happened twice now.
On my screen that shows mileage and oil life, the temperature reads as --- degrees F.
After starting the car again, it functions normally and displays the temperature.
I just wanted to know where the thermometer or temperature sensor is located so I can see if it's loose or something.
This will save me the trouble of having to take it make to the dealer and having them keep it overnight while denying me a loner car because im not 21....
Old Aug 6, 2008 | 02:23 AM
01tl4tl's Avatar
check your owner book to be sure- on my gen2 its directly below the hood latch assembly- in front of the radiator- attached with a clip
What does the owner book say about the setup screen and adjusting the temp reading- maybe thats the prob?
Old Aug 6, 2008 | 11:25 AM
bhelsdon's Avatar
Our temp meter only goes to 113 degrees and then in shows ---
it is attached to back of the front bumper. just to the drivers side of the middle of the car.
Old Aug 7, 2008 | 10:15 AM
shubysingh's Avatar
Thanks for the location.
It most definitely was not that hot, it never gets that hot in MD so somethin is definitely wrong
Old Jun 10, 2009 | 06:03 PM
jeff442's Avatar
The weird thing is that my car was broken into last week and the vent window on my driver side rear window was smashed. After having the glass replaced, the temp reads "-----". It seems far too coincidental, but how could these two be related?
Old Jun 11, 2009 | 08:35 AM
Majofo's Avatar
It's 115 and I'm going through a similar issue.. temp sensor is off by 10-25F.. This isn't a new issue but I forgot what the solution was..
Old Jun 11, 2009 | 10:59 AM
LoveMyTL-S's Avatar
Perhaps this will help, from the 3G garage:
https://acurazine.com/forums/3g-tl-2004-2008-93/acura-info-temp-sensor-logic-calibration-3g-garage-f-085-a-541717/
Old Jun 11, 2009 | 11:11 AM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
https://acurazine.com/forums/showthread.php?t=541717
Nice! But I don't know that I'd EVER be able to know the EXACT outside temperature...
Old Jun 11, 2009 | 11:12 AM
Majofo's Avatar
Thanks for the link!
Old Jun 11, 2009 | 11:18 AM
LoveMyTL-S's Avatar
This may also help:
http://www.in.honda.com/Rjanisis/pubs/SB/B05-029.PDF
Old Jun 11, 2009 | 11:28 AM
SouthernBoy's Avatar
Registered Member
You don't have to. When I calibrated mine, all I did was hang an accurate thermometer right next to the sensor and let it stay that way all night in my garage. The next morning I set my display to what the thermometer read and that was it. Works like a charm.
Old Jun 11, 2009 | 11:32 AM
Registered Member
If you do not reset this and you let your car sit for 5+ days, expect to have a dead battery. I know.. it happened to me seven weeks after I bought my '04 manual. You can remove the number 7 fuse (either 7 or 21 - not certain about which one but a search will turn it up) or remove the positive battery cable for around 15 seconds.
It appears that the ECU gets into an infinite error loop when this happens and continues drawing power from your battery.
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
RobbDizzle
Oct 15, 2015 11:16 AM
hrothgar02
Sep 28, 2015 11:08 AM
