What's this part next to the starter?
Old Nov 5, 2009 | 10:50 PM
GoldieATX's Avatar
5th Gear
I concluded today that my starter needed replacing. Removing the two long bolts that hold it in was no problem. There was much difficulty in removing the nut that attaches the solenoid wire, though (mostly due to a missing wrench). When I finally got a hold of it and popped it loose, the wrench smacked into the connection right next to it, and the whole thing broke clean off. See pictures.
What is this part, so I know what to get? And what's the best way to remove and replace it? Is it just all part of the bigger starter assembly? I have this feeling that I just haven't taken off the whole starter yet. Can someone please confirm? Thanks.
If I'm not mistaken, this is the whole starter, meaning I just broke a piece of the part I'm removing anyway:
http://www.autozone.com/autozone/cat...2_48987_0_1277
Some pictures:
Old Nov 6, 2009 | 05:04 AM
Turbonut's Avatar
That's part of the solenoid that will come with the new starter/solenoid. Just remove the 2 wires (large and small)from the solenoid, 2 bolts for the starter and it will come out. Looks like you removed the 2 long bolts that hold the housing/armature to the front housing. Wrong 2 bolts.
Old Nov 17, 2009 | 11:25 PM
GoldieATX's Avatar
5th Gear
Yep, just to update anyone else who comes across this...I had just removed (and broken) part of the solenoid attached to the starter. The starter itself is much bigger, and connects with a top and bottom bolt. I used a 17mm socket for both, and I needed a breaker bar to loosen the top one, I believe. Man, that was a pain. But once everything was off, it was an easy out-and-in. I could probably do the same job again in under 30 minutes. Thanks for the reply, Turbonut.
Old Nov 18, 2009 | 09:21 AM
Majofo's Avatar
^ you in the ATX goldie?
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
lovic87
Sep 15, 2015 06:07 PM
Sep 14, 2015 10:09 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
dlknight
Sep 3, 2015 07:54 PM
