What is this and why is it leaking?
looks like its your pre cat for front bank, its either coolant spill over the cat or it oil drip from oil leak at valve cover gasket.
Assuming you've already checked from the top where it might be originating from to pin point whether its oil from the timing belt area/covers or elsewhere. On my 07 TLS AT, the PS Pump was leaking from the outer case seal and the low pressure hose enough that itd make its way behind the alternator, by the ac compressor and down the side of oil pan and by the front converter. Looking at it from underneath itd be hard to mistake it for oil until you swiped it with your finger and smelled it.
if its oil then I would fix that ASAP, especially if it power steering fluid. Any veteran member here probably remember consequence PS leak in this video.
https://www.autoblog.com/2012/12/21/...aded-in-at-on/
BTW looks like Acura paid the owner to have the video removed from youtube.
