What is this and why is it leaking?
Old Nov 29, 2017 | 04:23 PM
Glorygang600's Avatar
This is at the front of my engine any info?
Old Nov 29, 2017 | 04:43 PM
truonghthe's Avatar
looks like its your pre cat for front bank, its either coolant spill over the cat or it oil drip from oil leak at valve cover gasket.
Old Nov 29, 2017 | 05:11 PM
So my pre cat is leaking?
Old Nov 29, 2017 | 05:14 PM
losiglow's Avatar
A pre-cat can't leak. Not fluid anyway. What truonghthe was referring to was oil leaking from the front valve cover onto the pre-cat, and likely along the side of the engine.
Old Nov 29, 2017 | 05:43 PM
so I'm due a new gasket soon? How long am I good to drive like this for?
Old Nov 29, 2017 | 07:39 PM
I mean, it's already pretty bad. Oil can ignite. That pipe is probably reaching temps of 100 degrees or more.
That's one concern.
Another would be loss of oil and could potentially starve the engine of oil.
Fix it sooner than later
Old Nov 30, 2017 | 05:52 AM
Should I go ahead and do a valve adjustment while im at it, im currently at 150k miles and see that ericthecar guy has 2 videos on how to do it
Old Nov 30, 2017 | 06:08 AM
if you want to?
doesnt hurt to check the clearance of the valves.
Old Nov 30, 2017 | 05:07 PM
if you want to?
Awesome thanks yoh
Old Dec 2, 2017 | 10:28 AM
001Stunna's Avatar
Assuming you've already checked from the top where it might be originating from to pin point whether its oil from the timing belt area/covers or elsewhere. On my 07 TLS AT, the PS Pump was leaking from the outer case seal and the low pressure hose enough that itd make its way behind the alternator, by the ac compressor and down the side of oil pan and by the front converter. Looking at it from underneath itd be hard to mistake it for oil until you swiped it with your finger and smelled it.
Old Dec 2, 2017 | 05:11 PM
truonghthe's Avatar
if its oil then I would fix that ASAP, especially if it power steering fluid. Any veteran member here probably remember consequence PS leak in this video.
https://www.autoblog.com/2012/12/21/...aded-in-at-on/
BTW looks like Acura paid the owner to have the video removed from youtube.
Old Dec 27, 2017 | 01:34 AM
CAM909RON's Avatar
LOOKS VERY SIMILAR SPOT WHERE I HAVE A LEAK
Old Dec 27, 2017 | 06:51 AM
rockstar143's Avatar
100 degrees!?!?
Old Dec 27, 2017 | 08:04 AM
Im going to be changing both head and intake gaskets and valve adjustment with a tranny swap im starting soon lyk how it goes.
Old Jan 1, 2018 | 06:23 AM
CAM909RON's Avatar
Mine was the head valve gasket and i had a friend change it and it stopped leaking
