What the hell happened?
Old Jan 22, 2013 | 01:50 PM
  #41
I hate cars's Avatar
Originally Posted by 08TypeS-CO
Check them often... even if they have never been touched since they left the factory. My #5 plug just cost me a motor and $8,200. Plugs were original and not part of scheduled maintenance intil 105K. I had 77K on the car when the plug blew. As I'm not the original owner of the TL, Acura would do nothing for me even though it is only 7K out of the powertrain warranty. Major rub is I own three Honda's and two Acura's but still no consideration. This TL I only bought 4 months ago!!Lesson learned I suppose. Schedule maintenance or not, check plugs no less than every second oil change. A small price to pay. One loose plug can do untold damage. I hope to have my car back by the end of the week. Found a used engine with 40K on it to replace mine. Repair shop will go over it with a fine tooth comb before installing to insure there are no surprises. At least it will be covered with a 12mo./12k warranty.
There's no reason to ever replace an engine from a plug blowing out unless you drove it for a very long time like that and washed a cylinder down from unburned fuel. At worst you're talking about replacing the heads but it's usually just a $300-$500 helicoil job.
Old Jan 22, 2013 | 03:06 PM
  #42
08TypeS-CO's Avatar
6th Gear
I would tend to agree if I wasn't sitting on this end but sorry it does happen. Car died as soon as check engine light came on and was towed to repair shop. Wasn't driven at all. Had head removed and confirmed threads were gone. Had a Time-sert repair done and the engine was put back together. Once shop was able to get it running there was almost no compression in the #5 cylinder. They did a leak test on the head and the issue wasn't there. Based on the results, without tearing the engine all down again, the only explaination is something from the plug entered the cylinder and caused damage. Unfortunately I have only had the car for 4 months and it ran well for 6,000 miles until it died. Pehaps the plug had been loose for a while and the selling dealer missed it in their inspection prior to reselling. Based on what I have read on several forums both Honda and Acura, this has been somewhat of an issue with the V6 3.5L engine. Seems the #5 plug is the normal culprit. Not sure if it is vibration from the engine that causes the plug to loosen, improper torque when the vehicle was built or ?? Some people seem to have gotten lucky and had no serious damage, only having to reinstall the plug. Others have had the threads in the head strip/melt out and have been successful with a helicoil or Time-sert repair. In many cases, severe engine damage requiring replacement of short blocks, used engine swap outs, etc. Unfortunately mine seems to have fallen into the latter. Two days after mine went into the shop they got a Honda Pilot in with...yep... #5 plug blow out. They were going to do the same repair with the Time-sert but haven't heard whether they were one of the lucky ones or not.
SidhuSaaB
May 30, 2020 12:40 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
Houston
Oct 8, 2015 01:27 AM
xsilverhawkx
Oct 5, 2015 11:00 AM
