What is this fastener called? How to remove?
Old Jun 30, 2012 | 03:54 PM
pohljm's Avatar
I am trying to remove the metal trim rings from the door panels. They are held in place by these black washer type fasteners that you can see get pressed into place over a metal stud. I have never had much luck removing them previously. Does anyone know what they are called and if there is a removal tool? Any help is appreciated
Old Jul 1, 2012 | 03:07 PM
paperboy42190's Avatar
Doesn't seem like those are meant to be removed. Maybe try grinding it off? It'd work but you'd have to glue it on back. Why are you removing it anyways?
Old Jul 1, 2012 | 03:26 PM
gwiffer's Avatar
I believe those are called internal tooth lock washers; you have to cut them off to remove them. I've used a dremel w/ cutoff wheel in the past, successfully.
You'll have to purchase new ones to reinstall.
Old Jul 2, 2012 | 12:06 AM
pohljm's Avatar
For the removal of the plastic speaker grill and replacing with fabric
cycdaniel
Dec 17, 2019 10:58 AM
pistacio
Sep 26, 2015 09:45 AM
k6biv
Sep 22, 2015 02:06 PM
04tler
Sep 10, 2015 01:13 PM
