What else to replace with oil pump re-seal?
Old Nov 4, 2016 | 09:28 AM
joker11's Avatar
My oil pump is leaking, about one drop of oil a day. I know it's not bad enough to worry about losing enough oil to be a problem, but it's enough to where I don't want to park in my friends driveway and leave an oil stain And unfortunately for this situation, the timing belt was already replaced so I can't get it fixed at the same time of that job because it was already done. I took it to my dealer and they quoted me about $950 to re-seal the oil pump and replace some o-rings on it. My question is what else should I have replaced while they are in there? I know most of the cost of this job is labor. So if there is some cheap preventive maintenance I can have done at the same time it would be good. I have a feeling there is probably some 10 or 20 dollar seal they could replace at the same time that might be a problem down the road but that is not bad now so they wont replace it...that is what I'm trying to avoid.
Old Nov 4, 2016 | 11:20 AM
Jackass's Avatar
In the same boat as you with my '05. Dealer quoted me $1300 and I told them for that amount of money, I can deal with a minor oil leak. Until mine gets bad enough that it starts dripping, I will leave it be.
Old Nov 4, 2016 | 11:37 AM
950 can buy a lot of oil and cardboard for the floor
Old Nov 4, 2016 | 06:59 PM
joker11's Avatar
Unhappy
Very true, I'm not too concerned about my garage floor, but I don't want to be the guy who has to park there car on the street because friends and family don't want my leaky TL messing up there driveway
Old Nov 6, 2016 | 05:18 AM
quantum7's Avatar
mine has been leaking for about 2 years now.....never drips. My place wanted $1600 so it was an easy choice to leave it be. Even when I had the timing belt done they only offered a couple hundred $ off.
If you have a timing belt change coming up you might inquire about how much they will discount since both jobs are almost all labor and they are in there anyway. I would wait until it gets really bad (if it ever does) or until timing belt.
Old Nov 6, 2016 | 07:40 AM
joker11's Avatar
As I said in my original post the timing belt was already done, it's not leaking to the point of mechanical concern(about one drop of oil a day), just an annoyance of leaving an oil drop wherever I park for a few hours Kinda sucks because I've owned multiple higher mileage cars that didn't leak oil
Old Nov 6, 2016 | 04:37 PM
truonghthe's Avatar
Have you ever replace the pcv valve? I would wait for the next TB/WP service if it not dripping.
Old Nov 6, 2016 | 05:45 PM
joker11's Avatar
As I said in my original post, it is leaking, to the tune of maybe one drop of oil a day. Which is why I was kinda thinking about getting it fixed and if there was anything else I should have replaced at the same time.
Old Nov 7, 2016 | 05:50 PM
quantum7's Avatar
Sorry for not reading the original post more closely, but paying $950 to fix a drop per day is not something I would do. For that money I would be annoyed for the times that I need to park in someone's driveway...or as suggested, use a piece of cardboard and park where ever you want and keep the grand in your pocket. The oil pump leak is a relatively common issue and again, for me, has not been any issue at all for a couple of years. At 230,000 miles I am not looking to drop a grand for fix a drip. My goal for the past couple of years is to keep my car away from the stealership which always seems to find plenty to fix while checking my car. I have turned to Acurazine to learn how to do most all of my repairs at home.
I wish you luck....
Old Nov 8, 2016 | 10:05 AM
isrraelmtz's Avatar
3rd Gear
Noticed oil on floor under TL
Hey guys! I need some help. So I noticed oil on the floor under my 06 TL I looked around and it seems like it's coming from the oil pump but not sure. I currently don't have the $ to take it to a dealership so I'm looking for options. Anyone here can help please.
Old Nov 8, 2016 | 10:12 AM
clean it up, degrease and monitor. Not much more to tell you as you haven't given us much to work from
spheregrid
Apr 4, 2022 07:36 AM
Fatfrii
Jun 10, 2017 12:57 AM
joker11
Sep 20, 2016 06:39 PM
Jesse729
Jul 4, 2016 08:03 PM
GK83
Jan 20, 2016 07:02 PM
