Wet sanding issue!
Old Aug 10, 2008 | 03:24 PM
mjferguson's Avatar
Wet sanding issue!
I tried to wet sand a little rock chip after touching it up. I was very hesitant to do so since I have never done this before. I followed all the tips on many web sites out there. I used 2000 grit and rubbed VERY lightly. well, I have a small spot around my chip now that appears "rough". Not shiny like the rest of the finish. I only rubbed it once or twice VERY lightly and checked to make sure I wasnt' doing any damage. Well, I guess I did? Any way to fix this without making it worse? I tried Meguiars paint cleaner and scratch X, didn't take it out completely. any other suggestions would be very appreciated. Thanks.
Old Aug 10, 2008 | 03:30 PM
consultauto's Avatar
you need to get it buffed out, I don't think you did any damage, the sand paper did it's job now all you need is a good buff job.
Old Aug 10, 2008 | 03:31 PM
mjferguson's Avatar
Anyway to do this by hand? What can I use to "buff it out"?
Old Aug 10, 2008 | 06:09 PM
take it to a good detail shop, a high speed buffer will be needed.
Old Aug 10, 2008 | 07:10 PM
Turbonut's Avatar
Get a wax with a cleaner and you'll be able to do it by hand. Will take a lot of pressure and rubbing, but you'll get the marks out.
Old Aug 10, 2008 | 08:27 PM
csmeance's Avatar
don't use a cleaner! You need a compound to take out the small sanding marks. The least is the best way to start. When I have to wetsand, I start out with scratch X like you used, if that doesn't work, I step it up to some Four Star Swirl Mark Remover, if that doesn't work I step it up to Four Star Medium Cut Compound. By then they are gone.
Old Aug 13, 2008 | 09:19 AM
vinnier6's Avatar
take some pics for us.....
Old Aug 17, 2008 | 10:55 PM
Jesstzn's Avatar
Hopefully you sanded in one direction .. if so get out the ScratchX again and a terry towel and use it across the sanding grain .. it will take a while but the terry will help with the cut needed.
Old Aug 18, 2008 | 12:33 AM
CJ0920's Avatar
Try using a rubbing compound, like turtle wax rubbing compound. That will fix your problem, then use a polish on top of that and should be good to go.
Old Aug 18, 2008 | 08:34 AM
Jesstzn's Avatar
Be very careful with this stuff ... you can create more issues than your curing .. and what "polish" are you suggesting he use?
Old Aug 28, 2008 | 08:41 AM
saplumm's Avatar
I'd recommend getting some polishing compound. You want to always start with a lower grit (your 2000 grit sandpaper) and then work up. Polishing compound on a slightly damp applicator should work. Follow that with you Scratch X or Nu Polish. Don't forget your wash and wax!
advan031
5G TLX Photograph Gallery
Nov 14, 2015 07:44 PM
eastcoastguy
Sep 24, 2015 02:07 PM
JarrettLauderdale
2G CL Dynograph Gallery
Sep 21, 2015 07:51 PM
