Weird Sound and Battery Issue
Old Jun 19, 2021 | 07:55 PM
notkious's Avatar
6th Gear
So I’ve had my Acura for a few weeks. When I first got it all was fine. It’s been sitting for about 3 weeks and if periodically turn it on and drive it around my before I got my tags. not there is a loud squeak coming from the timing belt and the battery has completely died (can’t even unlock from the key fob) I had jump start it twice within 30 minutes. The battery is new so i’m not sure what that issue is. Anyone else have this problem?
Videos:
Idle
Start
Old Jun 19, 2021 | 08:02 PM
the battery is draining from a parasitic draw. could be the infamous HFL(Hands Free Link) parasitic draw, or it could be another draw from somewhere else...you'll need to chase down where it's drawing from.
the squeal is a bad tensioner.
Old Jun 20, 2021 | 09:08 AM
notkious's Avatar
6th Gear
Ive heard about the hands free link drain the battery. I didn’t think it was an issue because I didn’t seem to work when I pressed the buttons. Thank you tho
Old Jun 20, 2021 | 09:44 AM
mariusz439's Avatar
Check the alternator.
The sound is one of the pulleys - not easy to figure out which one.
Old Jul 1, 2021 | 09:02 PM
Malmelst's Avatar
3rd Gear
It is your HFL drawing against it. Basically it is running in the background. Mechanic can turn it off, but then you don't have handsfree link access. I replaced mine as I got sick of my battery draining. Replacing it cured the problem.
User 12221
Oct 18, 2016 05:23 PM
nokkieny
Jul 18, 2011 02:52 PM
bricecakes
1G RL (1996-2004)
Nov 12, 2009 07:07 AM
gls
1G CL Problems & Fixes
Apr 15, 2006 12:09 PM
