Weird problem
Old Nov 24, 2009 | 03:58 PM
dave_ramkumar's Avatar
2011 ZCP E92 M3!!
Question Weird problem
i keep hearing a clicking noise wen im parking while im turning the steering wheel...it dosnt really happen wen im driving fast only wen i drive slow and turn the wheel or wen the car is not moving
dose anyone know what the problem is?
Old Nov 24, 2009 | 04:24 PM
RjG2's Avatar
If its only when you turn the wheel, its probably your power steering. You may just be low on fluid. Also check for any leaks in your power steering lines.
Old Nov 24, 2009 | 08:02 PM
2011 ZCP E92 M3!!
thx alot im gona go check it right now
Old Nov 24, 2009 | 10:53 PM
2011 ZCP E92 M3!!
the power steering fluid is god...its almost full
what now?
Old Nov 25, 2009 | 12:50 AM
Hi speed's Avatar
runnin a little boost
Sounds like it might be CV joints ( the connection between the engine and wheels ) if the little boot rips the grease can fall out and joint begins to fail.
Old Nov 25, 2009 | 10:40 AM
2011 ZCP E92 M3!!
if it is the cv joint how much do u think it would cost to fix
SidhuSaaB
May 30, 2020 12:40 AM
Fool
Mar 10, 2016 08:42 PM
12vancover
Oct 16, 2015 12:04 PM
Skirmich
Oct 1, 2015 12:59 PM
Matthew Purpura
Sep 25, 2015 06:10 PM
