Weird noise at highway speeds
Old Jun 18, 2011 | 08:23 PM
nY_o6_tL's Avatar
hey guys. i have an 06 tl..when im on the highway doing 50mph at about 1500-2000 rpms im having a weird sound almost sounds like a helicopter. i cant exactly pinpoint where in the car its coming from. ive done some research and checked the bearings by jacking up the car and trying to move the tires side to side and they seem fine..does anyone else have this similar issue or any noise at highway speeds? once im up to 60mph it seems to stop
Old Jun 18, 2011 | 09:10 PM
Jesstzn's Avatar
All windows and sunroof closed?
Old Jun 18, 2011 | 09:14 PM
nY_o6_tL's Avatar
yep and correct psi in all tires.
Old Jun 18, 2011 | 09:36 PM
iChinese's Avatar
did you get your tires changed recently? maybe it isnt balanced properly.
Old Jun 18, 2011 | 09:42 PM
nY_o6_tL's Avatar
well that could be because i bought the car in november and the dealer put new tires on it. they seem balanced properly though when i let go of them wheel it stays straight..could they still be imbalanced?
Old Jun 18, 2011 | 09:53 PM
nY_o6_tL's Avatar
also the car has fuzion HRI tires..can these be the problem?
Old Jun 18, 2011 | 09:58 PM
Jesstzn's Avatar
Balance usually shows up as a vibration in the steering wheel or felt in the seat.
Run your hand over the tread on all 4 tires .. both directions .. especially on the inside of the tread. See if you feel any feathering.
Old Jun 19, 2011 | 12:12 AM
Tehvine's Avatar
6spd FTW
Last car I had fuzions on... the tires got all kinds of noisy after I had them for a short while.
Old Jun 19, 2011 | 12:46 AM
Red Voodoo's Avatar
Area on my XM
I'm in agreeance with the tire noise theory. I have some tires on my wife's Mazda3 that produces a steady rhythm when at highway speeds, but not as audible at slower speeds.
Old Jun 19, 2011 | 01:46 AM
TheChamp531's Avatar
Chapter Leader (San Antonio)
You sure you're not doing something else while you're in the car?
Old Jun 30, 2011 | 06:29 PM
nY_o6_tL's Avatar
Thanks guys I have no idea what the issue is I'm also going with the tire noise theory. I've recently adjusted the press to 32 front, 33 rear as recommended in other threads and it has quieted slightly. I also read some reviews on my tires and pretty much have heard from everyone they're noisy as he'll on all cars.
Everything else seems fine with the car ie. Tranny, motor mounts. Is there anything else this could be??????
Old Jun 30, 2011 | 06:43 PM
EATSLEEPRACE's Avatar
6SPEED FEVER
its could be the tires because i had a set of kuhmo tires on my car and it was the worst......
Old Jun 30, 2011 | 06:56 PM
nY_o6_tL's Avatar
What'd it sound like?
Old Jun 30, 2011 | 08:41 PM
BukvaMan's Avatar
its a wheel bearing going bad no doubt. Over 60 mph you probably cant hear it over the wind noise.
Old Jul 2, 2011 | 10:37 PM
nY_o6_tL's Avatar
well i may have figured out what the problem is. i was washing my car today and noticed one of the tires has a rip in it. could this be where the noise is coming from??
Old Jul 2, 2011 | 11:46 PM
Jesstzn's Avatar
Put the spare on and see. Regardless.. replace that tire.
Old Jul 3, 2011 | 08:13 AM
nY_o6_tL's Avatar
Thanks yea I'm going to have it replaced today ill let everyone know how it is once it's changed. Never even noticed the rip it's a decent size too.
Old Jul 3, 2011 | 03:38 PM
nY_o6_tL's Avatar
Needed a balance. Took it to the tire shop and they checked it out both front tires were pretty worn on the inside and they were out of balance. Getting them put on Tuesday this should be the problem.
Old Jul 3, 2011 | 05:52 PM
jpm3071's Avatar
If they're worn on the inside be sure to check the alignment. Unless you have a camber kit they evenly wear.
Old Jul 3, 2011 | 05:58 PM
nY_o6_tL's Avatar
yea the two new tires will be balanced and aligned.. im also going to have the rears balanced and aligned just so everything is the same..
this should be the cause of the noise im hearing since the wheel shakes at 50 and above...am i right?
Old Jul 8, 2011 | 06:38 PM
nY_o6_tL's Avatar
Well $350 later the noise is gone and the car sounds better then ever.
The two front tires were out of balance which caused the insides to wear unevenly. One those were replaced and I was have the car aligned, we noticed my rear rim was bent. Fixed that for $30.
Never knew this car was this quiet on the highway lol.
Old Jul 10, 2011 | 02:28 PM
Jesstzn's Avatar
Usually balance issues won't cause tire wear .. I bet the toe settings were / are off.
Feb 25, 2020 09:57 AM
Frathora
Sep 28, 2015 11:29 PM
PortlandRL
Sep 14, 2015 12:01 PM
Dunnik
Sep 14, 2015 02:56 AM
Steven Vitek
ILX
Sep 10, 2015 07:29 AM
