Weird "clunk" coming from the transmission
Old 01-26-2011, 10:16 AM
FiveLiterCheater's Avatar
I recently noticed a weird "clunk" that I assume is coming from the transmission. It is very noticeable in the car, and does it VERY frequently. I narrowed it down to the throttle movement. If i tap the gas pedal and let go quickly, I hear the thump (usually from 2nd to 3rd gear). Now, if im on the the road driving normally and the car casually shifts from 2nd to 3rd it won't make a sound and it'll shift very well. It also makes this sound when i put it in Reverse, sounds TERRIBLE. I was pulling out of a parking spot earlier today, and as soon as I tapped the gas and let go I hear this sudden THUMP.
Transmission fluid was just changed less than 500 miles ago ( 3-step flush/refill)
What could it be? I also noticed when the car is in Drive, I get a lot of vibration @ idle that I can mainly feel through the steering wheel and brake pedal. Once I put the car in Nuetral, the vibration is almost non existent.
I'm hoping its just the engine mounts (or trans mounts?) and not something more serious...
Old 01-26-2011, 10:43 AM
bukjoe15's Avatar
sound like a motor mount issue. You motor mount could be bad and causing motor to rock back and forward.
Old 01-27-2011, 09:57 PM
dinks07's Avatar
I have the same issue changed the mount on the driver side still there all mounts seem jsut fine
Old 03-01-2011, 02:12 AM
9 mpg.
D's Up's Avatar
Any updates on this? I'm having the exact same issue. You perfectly described the 2nd-3rd gear scenario.
Old 03-03-2011, 02:35 AM
8th Gear
EscoMaya's Avatar
I believe its your motor mount as well, as I have the same problem. Pop your hood, put the car in drive, hold the brake with one foot and gas it with the other, see if the engine is jumping, better to check with 2 people, you can try it in reverse also. On my car its the passenger mount and front mount.
Old 03-03-2011, 07:39 AM
Majofo's Avatar
Received 11,841 Likes on 8,573 Posts
Motor Mount.
Old 05-11-2011, 02:47 PM
Had the car checked out, not the motor mounts. I'm guessing something is up with the transmission...?
Old 05-13-2011, 01:13 PM
I hate cars's Avatar
Received 1,812 Likes on 1,283 Posts
I don't know how they checked the mounts but visually you can't see a broken mount unless it's very bad.
You may have a hard part about to let go in the trans. I wish I had a diagram to see what parts are energized in the shift to 3rd and reverse. Still sounds like a mount with the idle vibrations which a trans can not cause.
Try shifting into drive and noting the vibrations. Then shift into reverse and note the vibrations. If the vibration goes away in reverse, it's the mounts. Actually, this doesn't matter. The fact that it goes away in neutral tells me it is the mounts for sure.
Old 05-13-2011, 01:22 PM
Majofo's Avatar
where did you get it checked?
Old 05-16-2011, 02:27 AM
It doesn't completely go away in neutral but it does subside considerably...which is why I originally thought it would be the motor mounts. I'll have another shop take a look at it...
Old 06-29-2011, 02:42 PM
nokkieny's Avatar
2005 TL 100k
I think I may have the same issue, My car does vibrate a little and it noticeably goes down when in neutral, When shifting from park to reverse there is a slight delay, than a thud.. Also at high speeds 65+ the car does shake, although this could be my tires as sometimes I can find a "sweet spot" where it does not vibrate, and the steering wheel shakes so maybe that would be tires.
Anyways, were you able to solve the issue fivelitercheater?
Which mount would be suspect? Or should I just get all 3 replaced?
mada51589
05-03-2022 08:54 PM
marcelft
07-10-2018 06:17 PM
nanos
11-12-2015 08:41 PM
mc1114
09-11-2015 05:50 PM
Desert Ridge
09-05-2015 09:47 AM
Quick Reply: Weird "clunk" coming from the transmission
