Water pump oil leak
So, are you stating that your water pump is leaking oil or leaking coolant?
Coolant can leak from the area indicated by the red arrow with wear below or the periphery if the fasteners are loose.
And / or are you finding oil or exhaust gases ('bubbles on the coolant') in the #1 coolant reserve tank below?
