Oil leak , coolant
Old Mar 7, 2026 | 03:24 PM
bohemianhwy's Avatar
Oil leak , coolant
My 2005 TL aspec 225 K , keeps burning/leaking oil I keep an eye on the levels , however the coolant seems to go down every other month and I cant see a leak , it runs fine otherwise , any suggestions? doomed?
Old Mar 7, 2026 | 05:16 PM
When was the last time the water pump was changed?
Old Mar 8, 2026 | 06:38 AM
mariusz439's Avatar
Had similar symptoms - needed to add about 100ml each month. However couldn't identify the leak. It lasted 4 or 5 year untill this year when my radiator finally broke and ATF mixed with coolant.
Take torch and check carefully the radiator for microleaks, that's can evaporate without dropping on the ground.
Old Mar 8, 2026 | 01:27 PM
EasyLoveRDX's Avatar
Make sure you don't have any forbidden milkshake in your oil or trans fluid
Jackhammer
1G RDX Problems & Fixes
Aug 15, 2025 01:35 PM
germicide
1G RDX (2007-2012)
Nov 28, 2024 01:27 PM
Gregory Kozlowski
3G RDX (2019+)
May 18, 2020 10:29 PM
Yikes
Nov 26, 2012 03:45 PM
kvan2007
Aug 25, 2012 01:32 PM
