Water Leak - Passenger Side Rear Floor
I've seen a couple of posts about water under the rear floor mats but haven't seen anything about a cause. I see where an NHTSA service bulletin has been issued over this and I'm having the very same problem. This is NOT the ABS grommet problem causing water under the rear seat. It's a leak coming through the door somehow. Anybody have any info on this????
wlecometo the fourms. I think this could be due to a bad weather seal (rubber seal) around the doors. Also it might be due to another thing such as an accident that may have occured. Also take it to acura if you haven't and have them diagnose it.
I do my own work.
It could possibly be a clogged sunroof drain. when this happens, water often leaks into the trunk; however, I've seen it leak into the rear seats before...it's a possibility.
mike from annapolis
05-07-2017 08:21 PM
nanos
11-12-2015 08:41 PM
