Water leak in driver door
I have an '07 TL-S 6sp with about 2300 miles on it that makes my life 131% better. Recently we have had some crazy rains in Chicago and I have noticed that a good deal of water seems to be leaking through my driver side door. When I open it after rain there is quite a bit of water on the aluminum "Acura" plate and even some water in the groove on the rubber seal just before the carpet. I have looked at the underside of the door and there is quite a bit of water clinging to it's bottom - even the inside edge. I can't find any obvious seal problems around the window or door. The windows have been completely up. Any thoughts? Thanks.
I too have experienced this. Have had the car 4 months but haven't had much rain until about twoo weeks ago. I need to take mine in - the seal seems to be separated from the body of the car about 1/16 of an inch. Definitely noticably different than the other four door seals. Same car - 07 TL-S.
Problem is, deal is a pretty good commute for me.
rockyboy
Aug 4, 2024 10:35 AM
tman570
Jun 11, 2019 07:56 AM
