Water damage to screen?
Old Sep 3, 2012 | 05:32 PM
eightpak's Avatar
6th Gear
Hello all,
I have a 2004 tl with navigation. About 2 gallons of water spilled in the truck of our car. I did my best to get it all out.
Next day the screen had backlight but black/blank screen. The radio works, the time shows on the upper screen but no radio digits are shown.
Nothing on the main screen seems to be functioning.
I took out the dvd player in the truck to see if it had water damage. Seemed totally fine.
I have no idea where to start, any advices other than take it to the dealer?
Old Sep 3, 2012 | 07:19 PM
IamaTL's Avatar
I like turtles
Water spilled in the trunk, yet the navi isnt working? It would have to be the dvd player
Old Sep 3, 2012 | 09:16 PM
truonghthe's Avatar
DVD navi unit seem death to me, you can buy it used unless you want to spend $2200 for a brand new one.
Old Sep 3, 2012 | 09:37 PM
SpiderX1016's Avatar
I'd air out the dvd unit for a few days to a week and hope for the best.
I'm not sure if you can send it in for water damage repairs. I'd call Alpine or the dealer and see.
Old Sep 4, 2012 | 05:43 PM
eightpak's Avatar
6th Gear
So everyone is for sure its the player? Couldn't have been a fuse by it or anything small I am not seeing, right?
The real damage would be to get a new one to find out its not the issue :P
The dvd player has power and cd in/out buttons are functioning.
I will try to dry it some more.
Also, does it make sense that the radio is working but the radio digits arent showing on the small screen above the main screen when everything else is showing like the time?
Does it still mean its the dvd player?
Old Sep 4, 2012 | 06:23 PM
EvilVirus's Avatar
dont air it out; stick it in a bag of rice (no joke.....research it) it helps remove moisture from electrical devices. just leave it there for a couple of days.
Old Sep 5, 2012 | 11:27 AM
ZOMGVTEK's Avatar
It's most likely the nav unit in the trunk thats the issue. Drying it out won't hurt, but it's exceedingly likely that will not fix the problem long term. Liquids tend to really cause all sorts of odd issues to electronics. Even if the issues go away, don't expect it to be permanent. The nav unit is probably not very well conformal coated, especially since you are experiencing issues. All it takes is a tiny bit of corrosion that allows some signal to go where it shouldn't be and the unit is dead.
I'd be on the lookout for a replacement.
Old Sep 6, 2012 | 05:14 AM
paperboy42190's Avatar
honestly i think it's dead. When electronics short circuit, there's usually no going back. Airing it out only helps if you never turned on the unit after spilling the water.
Old Sep 6, 2012 | 05:15 AM
this is why you should get the trunk mat i got mine for $20 picked up locally and it's saved me from a very messy trunk a few times already from accidental spills.
Old Sep 9, 2012 | 08:42 AM
eightpak's Avatar
6th Gear
Thanks for all the answers guys.
What do you guys think about the radio digits not showing on the top mini screen?
ValdezQ26
Oct 1, 2015 04:48 PM
Jboat
Sep 30, 2015 10:58 AM
RadiantCycles
ZDX
Sep 26, 2015 09:18 PM
STL TL-S
Sep 23, 2015 08:52 PM
