Water.
Old Mar 5, 2010 | 05:59 PM
ImPoRtHoNdA's Avatar
My username is lame
Water.
For some reason, i usually drive my car every once in a while without the music on just so i can listen to the car, to see if anything sounds weird. About 2 weeks ago, i did this, and i hear a swoosh sound of water every time i accelerate. Every time i slow down, depending how far of a distance, i hear the swoosh of water again. I think to myself, oh its prob. just a water bottle that got rolled under the passenger seat or something, no big deal. Today, since its finally not raining, i decided to take that water bottle out. i go under both seats, and NO WATER BOTTLE. can't seem to figure out where this water sound is coming from. Anybody have any ideas???
thanks in advance!
Old Mar 5, 2010 | 07:10 PM
Turbonut's Avatar
Did you check the water level?
Old Mar 5, 2010 | 07:34 PM
shftl's Avatar
Don't want to scare you, but read this thread--there are at least two others on the same point.
https://acurazine.com/forums/3g-tl-problems-fixes-114/car-wont-start-ac-froze-up-now-pcm-full-water-736795/
Before you do anything else, try to determine if your ac drain hose is blocked.
Old Mar 5, 2010 | 08:45 PM
nfnsquared's Avatar
^^^^^^ x2....or, hate to say it, blown head gasket.
Check your A/C drain hose to be sure it's not plugged up, either by an oil change tech plugging it with a screw (yeah, it's really happened, more than once) or by road crap.
Hopefully it's nothing.
Old Mar 6, 2010 | 08:38 AM
g2teg's Avatar
I hear the same thing, I checked everywhere and no signs of water inside the car. I just thought it was the gas in the the tank moving around.
Old Apr 28, 2010 | 08:37 PM
g2teg's Avatar
I was sitting in my car and revved it a couple times and I can get it to make that sound. turns out it was low on coolant. topped it up and no more noise.
Old Apr 29, 2010 | 08:59 PM
eg5's Avatar
eg5
user title goes here
if he indeed had a blown head gasket, dont you think his concern would be about how shitty the car idles and lack of power. how would a blown headgasket cause a water swoosh sound?
STL TL-S
Sep 23, 2015 08:52 PM
