Warped Rotor
Old Jul 17, 2006 | 08:16 PM
K-man's Avatar
Question Warped Rotor
I have been telling my Acura Technician since 14,000 miles that the my 05 TL shakes when applying the brakes at highway speed (60-70 mph). 2 services later still they could not find anything. Finally, at 29,000 miles I took the tech for a ride and he immediately said the rotors were warped and I needed an entire brake job. After doing some research I found that in 2003 there was a service bulletin posted for this problem. I pointed this out to the service desk manager when I picked up the car and he said that was an old problem and was fixed. Is this true? I have never known this as maintenance and none of my previous cars ever experienced this problem. Does anyone have any current info on this? I have taken it up with the Regional office. I think it should be under warranty.
Old Jul 17, 2006 | 11:34 PM
EternaLlx's Avatar
6speed NBP
I've seen a few people with warped and some of them got it replaced for free but they were under 10k miles if i remember correctly and the people that were over that had to pay for it.
Old Jul 18, 2006 | 12:04 AM
frenchnew's Avatar
I have an appointment with my local Acura Dealer this morning @ 9:30AM to replace both rear disc that are rusted beyond recovery on my 2005TL that is 15 months old with 36,000KM on it. The front ones are in perfect shape. The one on the rear are rusted and deeply grooved.
They already look at it las week and told me they would replace them No Charge.
I will keep you posted.
Best regards from Montreal
frenchnew
Old Jul 18, 2006 | 04:10 PM
K-man's Avatar
The Regional Acura office called this morning and offered to refund me 50% of the repair cost as a one time gesture of goodwill, about $180. I agreed to accept with the miles on the car and uncertainty regarding the actual cause. Thanks for the comments.
Old Jul 18, 2006 | 04:14 PM
frenchnew's Avatar
I just returned from the dealer.
They have replaced both rear rotor and brake pads under warranty. According to the mechanic, certain 3rd Gen TL do experience these kind of problems and Acura applies warranty on a case per case basis.
The mechanic did mention only seeing this on the rear rotors of the 3rd Gen TL only and not on any other Acura.
Best regards
frenchnew
Old Jul 22, 2006 | 06:30 PM
Type S Zero's Avatar
hi frenchnew !
i'm the one that took care of your car
the rear rotor rusting problem was solved on the 2006 model. 04-05 models have this problem and Acura investigated on the case and finally released new rotors and pads (using the same parts # though)
we usually machine the rotors on a brake lathe when still within specs (first time doing brakes or first time rotors warped), but the problem here is that the rust gets so deep on rear 04-05, we'd be machining them for so long and most of the time get the rotors too thin (getting them out of spec).
so there's no recall nor service bulletin on this, but they are aware of the problem, investigated it and released new parts.
Old Jul 22, 2006 | 07:07 PM
DMZ's Avatar
DMZ
Head a da Family
One way to help prevent warped rotors on Hondas and Acuras is to NOT OVERTIGHTEN the wheel lug nuts.
They're supposed to be at 80 ft-lbs. Make sure any shop that removes and reinstalls your wheels does this.
Old Jul 22, 2006 | 08:54 PM
frenchnew's Avatar
Originally Posted by Type S Zero
hi frenchnew !
You are the King my friend, my car rides and brakes like new.
I'll have to stop in next week, Are you on vacation?
Best regards
frenchnew
Jul 16, 2017 07:33 AM
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
lanechanger
Oct 13, 2015 10:56 AM
08_UA7_Gr33k
Sep 27, 2015 01:56 PM
