VTEC actuator motor cap. so simple yet so hard to find replacement!
Old Apr 13, 2017 | 07:14 PM
Fatfrii's Avatar
Upon doing a valve cover gasket change and valve adjustment, I noticed a crack on a cap on the vtech actuator that goes on the intake manifold right right next to the power steering pump. I took it off to take a look and it was so brittle it basically crumbled off. It was just a little gray plastic or rubber (that turn hard and brittle like plastic) cap that covered the white part where my thumb is pointed. I dont know how important it is or what will happen if I drive with it like this for a long time so I want to replace it with some sort of similar sized cover. The little cover is not sold individually and a whole new actuator costs over 200 dollars. Im not down for that since all what is wrong with it is a missing little rubber cap. Iv walked around oreily's, autozone, and even home depot just to find something to cover it and have had not luck. I have found that I needs to be 14mm or 9/16th inch in diameter. Does anyone have any kind of suggestion on what to replace it with or what its even for or how important it is to replace. I have here a picture of mine followed by the best pic i can find on google. here is mine
the gray cap missing is the only issue
Old Apr 13, 2017 | 07:43 PM
thisaznboi88's Avatar
That's not vtec. It's for the intake manifold runners butterfly. You can get a cheap one for 20 bucks off eBay
Old Apr 14, 2017 | 11:10 AM
truonghthe's Avatar
ebay or car-parts.com for cheap, you don't have to buy a brand new one.
Old Apr 14, 2017 | 01:42 PM
Fatfrii's Avatar
thanks for the tip guys but I havnt found any that cheap and I just want to find a substitute cap but cant think of where to find one
Old Apr 14, 2017 | 02:16 PM
truonghthe's Avatar
I am not so sure where you got your OVER $200 figure from but even NEW from Pedoria cost about $106.91.
https://www.oemacuraparts.com/auto-p...nifold-07-scat
Number 5 is what you looking for.
Here is couple one used going for $35-$45,you need to do MORA RESEARCH SIR!
Honda Acura Denso Actuator Assy. Bypass Valve Solenoid Sensor 17150-RNA-A01 OEM | eBay
Old Apr 14, 2017 | 02:43 PM
Old Apr 18, 2017 | 03:36 AM
Fatfrii's Avatar
im just wondering if the engine will explode or not without the cap on
Old Apr 18, 2017 | 07:32 AM
only one way to find out!
Old Apr 18, 2017 | 09:09 AM
BreezyTL's Avatar
I have a cap I will sell. Shoot me a PM if interested.
Old Apr 21, 2017 | 09:35 AM
BreezyTL's Avatar
Old Apr 21, 2017 | 09:54 AM
alexb92's Avatar
Old Apr 21, 2017 | 10:05 AM
fixed title
Old Apr 21, 2017 | 02:51 PM
Fatfrii's Avatar
Originally Posted by alexb92
lmao! oops
Old Apr 22, 2017 | 01:58 PM
truonghthe's Avatar
I seen this coming miles away lol.
Old Nov 18, 2018 | 12:29 PM
afrances44's Avatar
5th Gear
anyone know the correct alignment with this bypass valve and the butterflies off the intake manifold?
RLX-Sport Hybrid
3G RLX (2013+)
Jan 14, 2015 11:47 PM
Dan
2G CL Frequently Asked Questions
30
Jun 10, 2014 10:09 PM
gavriil
Sep 16, 2007 08:15 PM
Excelerate
30
Nov 15, 2005 12:09 PM
bmencig
Nov 7, 2004 09:01 PM
