VSA and ! Light
Old May 19, 2012 | 07:01 PM
4play's Avatar
VSA and ! Light
I just had my clutch changed by my mechanic and after the install the VSA light and ABS light came on.
After running a diagnostic test, the scanner found a bad driver's side speed sensor. After installing the speed sensor, the abs light and VSA lights turned off (even before running the scanner).
After a few miles of test driving, the VSA light and ! light came back on and stayed on. We ran the scanner again and the scanner said "sensor" not specifying which one.
The light turns off every time i restart the car, but comes back on within a few minutes of driving. Can anyone help?
The car accelerates and brakes normally still. I've read about other's app sensor going bad, but they have problems with their brakes and say their cars jerking. I don't know where else to look.
Old May 21, 2012 | 10:34 AM
4play's Avatar
the code is 84-1 VSA
Old May 21, 2012 | 01:07 PM
4play's Avatar
researched some other forums and it may be the neutral posion memorization that needs to be reset. will try to reset the code with my bluepoint scanner and follow the neutral postion reset procedure
Old May 21, 2012 | 09:03 PM
lankanboy1's Avatar
After changing your Speed sensor you need to calibrate your sensor.
Old May 22, 2012 | 03:41 PM
4play's Avatar
how is this done?
Old May 22, 2012 | 10:44 PM
lankanboy1's Avatar
well how i did is with the gna600 cost over 600$(clone) but i think some obd scanner could do it or the stealership. it woudnt take more then 45 sec, so ask the dealer they might be able to do it for a small fee.
Old May 24, 2012 | 01:32 PM
4play's Avatar
ah i was afraid i would have to take it to the stealership. they charge an arm and a leg just to scan a car.
Old May 24, 2012 | 10:44 PM
lankanboy1's Avatar
or find a decent honda mechanic on your are they will do it for less then 20 $
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
Rob144
Sep 21, 2015 08:18 AM
bryan zaragoza
Sep 8, 2015 12:28 AM
