VSA Light !!!
Old Mar 22, 2007 | 10:13 PM
vpopat's Avatar
6th Gear
Angry VSA Light !!!
Ok, I just bought a 2005 TL with 30K on it, the VSA Light came on the 2nd day I had it, so i brought it back to the dealer and they replaced the "Yaw Sensor", which didnt do shit.
So... 20 miles later, the light comes on again! I take it back and they replace the "control module"....which helped for 1 week, then it happened again...but not just popping on, it came on after a grinding noise... so its in the shop for a third time.... what do i do, return the car because its a lemon, how does it work... can anyone tell me if they have had the same problem.
Thanks everyone
Old Mar 23, 2007 | 12:22 AM
csmeance's Avatar
lemons don't apply to used cars, at least in my state. But go bac to the dealer and have them check out the entire system. Since you heard a grinding noise, tell them to check all the sensors, suspension compnents, check for shorts in the wiring.
Old Mar 23, 2007 | 03:49 AM
datmrman's Avatar
Found these with a keyword search for vsa*:Hopefully they offer you insight. Otherwise, theres a few more threads you can find with a search. Good luck on getting your problem solved.
Old Mar 26, 2007 | 12:25 AM
pohljm's Avatar
I had a wheel speed sensor get chewed up in its sealed area inside the steering knuckle, mine did not make any sounds that I heard but it triggered the VSA and ABS lights., The sensor pieces could easily fall into the wheel bearing from that location. Mine was replaced under warranty, but its still a mystery how it may have happened.
mada51589
Jan 9, 2025 04:40 PM
cycdaniel
Dec 17, 2019 10:58 AM
hedzup
1G RL (1996-2004)
Jun 29, 2016 08:07 AM
Rob144
Sep 21, 2015 08:18 AM
bryan zaragoza
Sep 8, 2015 12:28 AM
